New TSB for 3.5 GDI Sartup Rattle 15-0131
Started by BiGMaC, September 05, 2015, 10:19:59 AM
Woody
Quote from: salsathe4th on June 07, 2016, 06:13:15 PM
Anyone try BG products and had success getting rid of the start up rattle? Im using Amsoil and the rattle is pretty bad.
And by the way mine sounds exactly like the posted video. What year is your Lincoln? Hopefully mine is under the same warranty.
My MKS is a 2012 with 65k.  It already had the 6/100 certified used warranty and I bumped it up to 7/125.  I see people saying it should be covered under emissions warranty though.
They are killing me.  They told me they are waiting on the chain and will have my car another weekend (it will be 2 weeks Tuesday)  In the next breath he says "The H&R lowering springs made it look really great."  Yeah, thanks for telling me after telling me I won't see it for another 4+ days.
sholxgt
Quote from: Woody on June 10, 2016, 01:22:42 PM
Sorry :(
Seems that Ford is doing worse than usual for parts.  My car has been down for 12 days waiting on the HPFP gasket in order to fix a monumental leak in the valve covers.  My wife, who works at the dealer, had Lincoln get involved and somehow they were able to get a gasket in a couple of days instead of the 6/22 date Ford provided.
How they can be out of a simple gasket that has been used since 2010 on every transverse 3.5EB is beyond me.
Are you in a dealer provided rental?  That usually spurs them to action much quicker.
John Miller
#122
So I am out of town for the summer, and my rental ended up being a 2016 Taurus SEL V6.
I realize it is not the EB but, like the 2011 SHO I test drove, it is quiet on startup, and is much quieter and smoother sounding during idle than my 15 SHO.
I really believe this is a loose timing chain issue. For mine, the startup noise also translates to a much more CHK CHK CHK sound at idle than those without the issue I have driven. That sound isn't offensive necessarily, but is coming from the same area of the engine as the startup noise. At idle, I would describe it as a very muted version of the noise in the videos in this thread - so I believe it to have the same root cause.
The mystery to me is whether Ford will end up calling this a "normal operating characteristic," given is has no affect on performance. So Woody's results interest me. When I get back in the fall, I might make an appointment with my dealer and give it a shot .... depending on what transpires here in the meantime.
2015 Taurus SHO, Non-PP, 93 Octane Livernois V10 "Soft Shift" Tune with 170 Reische Thermostat and 3-bar MAP sensor
I think what your hearing in the sho is the direct injection fuel pump on top of the front valve cover. It has a very distinctive tick sound.
The non ecoboost is a sequential multi port.
John Miller
Except that the 2011 SHO I drove didn't have the noise to which I refer.  Or maybe I am hearing the DI, and it is just louder on my car than the one I test drove.
Who knows.  I know it is hard to diagnose noises on the internet.  But, if I was a bettin' man, I'd put $ that the start-up noise, if fixed, would quiet down my normal idle as well.
Very likely the rental is well-maintained and/or has the OEM oil/filter in it.  The 3.5 is pretty quiet in the cabin, not so much once you open the hood and take the cover off :)
Woody
Quote from: sholxgt on June 10, 2016, 01:32:50 PMSorry :(
Yeah.  My dealer is good about the loaners.  I have extended warranty.  I am in a 2016 MKX AWD.  Not an ecoboost, but I really enjoy this vehicle.  Doesn't seem to be spurring them on at all.  My car will be gone 2 weeks on Tuesday.  But I am having a lot of other work done and the bill is pretty high.  It's going to be like a new car. :)  Plugs, new chain, H&R's, full detailing, front brakes, coolant and rear diff fluids.  Tempted to do a tune with all this stuff touched up. :)
TX MKS-T
Quote from: John Miller on June 09, 2016, 10:59:51 AM
Quote from: TX MKS-T on June 09, 2016, 08:37:18 AM
Made the Amsoil/Ford filter change at begining of May and all is still quiet every morning when starting.
Are you sure you were experiencing the same thing presented in any of the three videos from prior posts in this thread?
I had the split second ticking on startup, no CEL but definately ticking that went away quickly. I know this thread has both examples and the suggested oil/filter combo helped my issue as indicated in earlier pages.
2010 MKS-T * K&N Drop In/Power Stop Rotors
2007 Tundra TRD 5.7 - The Toy Hauler
2014 Mitsu Outlander - Kid Hauler
salsathe4th
I find when it is warm/hot outside it'll rattle REALLY loud but when its cool/cold it barely rattles at start up. Can someone explain why that is?
"Do or do not, there is no try"         2010 MKS, 22" Motiv Maranello Rims, Mdesign CAI with VTA, LMS 4X tune and lovin' it
-master yoda
Is this observation based on fresh oil, midlife oil, or endoflife oil? Could be viscosity changes, could be parts expansion (ie, timing chain tensioner) in hotter weather, OTTOMH ...
http://www.agcoauto.com/content/news/p2_articleid/115
salsathe4th
Quote from: SHOdded on June 14, 2016, 11:39:34 PM
I got about 1000 miles so far with my motorcraft filter and aimsoil.
-master yoda
How does the rattle respond to RPM, and how long does it last?  The belt tensioner might be worth looking into also.
Quote from: SHOdded on June 15, 2016, 06:30:53 AM
I thought the rattle sound we were hearing was the tensioner ratcheting out when the oil pressure increases.
Not the actual chain slapping around.
It's probably a combo of both.
IDK, trying to ascertain whether this sound when warm/hot is related to oil at all or not.
93Cobra
The clicking you hear is from the cam phasers. These don't seem to last very long. F150 folks are feeling the brunt of this right now.
