f8tlsho how mature was the tune when you ran? How long was the tune on the car when you ran? No downpipes either?
That is a solid time I think for that boost..Makes me optimistic of times I may run. Your desired TIP was about 203kpa. So you were targeting around 15psi throughout the rev range and gears through the run. That's exactly what I've been running while I've been working on some things....I thought I would have to run more than that to run that kind of time.....You didn't have any knock...Your boost spikes on upshifts but that's an unavoidable condition if the throttle stays open, which it did....The stock tune will regulate that with the throttle. Your boost falls off a bit near redline but it's not bad at all, I've seen worse. You have to tell it when and where to add wastegate duty cycle.
Anyway nice run and thanks for the datalog...You basically log the same stuff I do...I've been wanting to see a nice time with no meth and data with items similar to what I would log so that fit the bill near perfect
