Has anyone upgraded their trans cooler?
Started by Gray Brick, August 11, 2015, 01:04:56 AM
Looks nice....Why can't we have that on our GPS screens?.....I don't have one of those fancy tablets and I'd hate to look at that on my phone
Quote from: ajpturbo on August 11, 2015, 11:43:04 PM
Because in Ford's infinite wisdom the equipped our 45k tech flagships with composite video inputs.
Well I'm not a computer guy at all...We have Bluetooth...Can't you do a type of wireless or dongle or something from the OBD II port ...I'd run the composite cables  to the screen if I could see all those gauges.
Gray Brick
HDMI to composite converter... $20 on ebay.
The problem is you need a Lockpick device to watch composite while driving.
2013 Ecoboost Ford Flex
Quote from: Gray Brick on August 12, 2015, 03:33:51 AM
Nah, I'm just gonna blow $429 on the new Lockpick Air....
Quote from: FoMoCoSHO on August 12, 2015, 02:09:06 PM
What's that all a boot?
Quote from: ajpturbo on August 12, 2015, 02:40:58 PM
http://www.coastaletech.com/mytouchair.htm
So I just took the BBG out for a flogging to watch the trans temps....
Highest temp was 196 and this was a fairly extensive flogging....far worse that dragstrip days with the 2013  non pp that saw temps over 220
As soon as the flogging subsided temps dropped very quickly to the low 170's for normal cruising.
This is a 2015 pp that had a drain and fill with Amsoil at 150 miles.
YMMV
Gray Brick
170 sounds good.
Is the cooler different in the SHO compared to the Flex?
FoMoCo has the 2015 Performance Package, his 2013 did not.  The Flex has the same componentry as the non-Performance Package SHO.
How do the differences look (for 2010-12 anyway)?  See the attachment in bpd's post here:
http://www.ecoboostperformanceforum.com/index.php/topic,522.msg3161.html#msg3161
SHO Performance Package
$1,300
Enhance the performance of your SHO with the available SHO Performance Package. It features:
• Upgraded performance brake pads
• Sport-calibrated electric power-assisted steering (EPAS)
• Higher-rated springs, tuned shocks, stiffer stabilizer bars and rear suspension to provide a more connected feel between the driver and the road
• Standard AdvanceTrac® electronic stability control (ESC) features a "Track Mode/True Off" setting that delivers a more spirited driving experience
• 3.16 final drive ratio for off-the-line acceleration
• 20" machined and painted wheels with performance summer tires*
• New larger front and rear brake rotors
• Upgraded cooling pack
• Tire mobility kit (in lieu of spare tire)
• Alcantara® suede-wrapped steering wheel
*Ford does not recommend using summer tires when temperatures drop to approximately 40°F or below (depending on tire wear and environmental conditions) or in snow/ice conditions. If the vehicle must be driven in these conditions, Ford recommends using all-season or snow tires.
30 minute drive to work today, 3 10ish minute segments consisting
City/hwy/city
156 degrees when I pulled in.
I suppose you could keep some cold ones in there, FoMoCo!  ;)
Gray Brick
Does Ford offer the aux trans cooler for the Flex?
