Unfortunately not. It looks like the drive only holds data such as your ripped CD's, map data, and some some of the graphic elements such as the startup ford logo and the background. If you remove the drive and turn on the head unit, it will "work" though it will say it's having a problem and you are limited in the use, such as the radio. I think the main OS is stored on the board inside the head unit itself, so without the proper tools, I don't think there is really a way to modify it. One this I did notice on one of the main boards in the head unit is an SPI interface, one might be able to interface with that, though I am not really sure what you get, if anything. As far as the OS, there might be a way if you could get a set of clips that would fit on the onboard storage chips, I might do some more digging into it...
Quote from: J-Will on August 19, 2015, 09:11:33 AM
Have you been able to turn your image into a VM? This should allow you to pull out any drivers in order to create a custom image (Win 10 or bare CE)
