PID for PTU Temperature
Started by Gray Brick, August 09, 2015, 01:10:39 PM
Gray Brick
I can't seem to find this.  Is this an available PID?
Does the Flex/SHO have a PTU temp sensor!
2013 Ecoboost Ford Flex
I believe only the 13+ PP SHO  have it.
I'm not 100% positive though.
ecoboostsho
Yes it's 13+ PP only. The PID is 22070D and formula is same as the trans temp.
The PI's should also have this available, maybe the XSport.  No idea on the Flex.
Gray Brick
I will try it out on the Flex and let you know if it works.
66 Galaxie
IIRC only performance pkg (SHO) and police package vehicles (Taurus & Explorer) have a PTU temp sensor as well as the PTU fluid cooling.
Please let us know if you have any success.
Gray Brick
No luck. :(
Quote from: 66 Galaxie on August 10, 2015, 06:02:47 PM
:(  Sure you got the formula correct?  Sometimes an extra space here or there will kill it.
Gray Brick
I copied my formula from the coolant temp.
Please send me the formula you suggest.
Gray Brick
I don't have the sensor on the Flex.
Is there a way it can be added?
I don't think the computer is enabled to accept the sensor data.
66 Galaxie
Reviving an old thread:
Anyone know if the non PP SHO has the temp sensor wiring in its wiring harness?
For those with PP can you post a picture of the wire and where it comes out of the harness?
Thanks guys!
Quote from: 66 Galaxie on January 08, 2017, 09:28:52 AM
Thanks guys!
I have a few pics LMK if this helps any.
66 Galaxie
Thanks!
Looks like it plugs into the wiring harness up on the firewall.  I would guess the actual harness it plugs into is the engine wiring harness.  If so I'll need to do some homework to see if PP cars use the same harness as non PP.
ecobeast13
What temps are you guys seeing? ive seen mine as high as 190 on a hot day... cools down on idle.. (13 pp sho)
