Quote from: SHOdded on August 14, 2015, 04:07:59 PM
In the wintertime, those of us blessed enough to be in the salt belt might use products like HEET that contain methanol. Do you recommend adding ACES IV or ACES IV-A to the gas tank at that time?
If you are using ACES IV in the fuel, there will be no need to add any methanol to your tank ever.
I understand the reason to wick the water to the methanol. I always suggest people keep their tanks filled in the winter anyway but if that is not possible, the water that is created by condensation will be broken down into their respective parts of hydrogen and oxygen and added to the fuel and burned harmlessly using ACES IV.
This is probably a good time to go over what the ACES IV contains:
DETERGENCY - This characteristic has a high detergency action that keeps solids and carbon from settling on the components and keeps the entire system clean and free of deposits.
GUM AND VARNISH REMOVER - Eliminates gum and varnish in the tank bottoms and sidewalls.
FUEL SYSTEM CONDITIONER- This is important for both carburetors and injectors to produce the correct spray pattern that will promote volumetric efficiency. If an engine can't breath it cannot produce the power it was designed to provide.
FUEL PUMP AND INJECTOR CLEANER – A designed solvent compound that delaminates and cleans your fuel pump and injectors from within the fuel. This improves the spray pattern and gets the engine to have a vaporous spray and not atomized spray patterns.
BTU - ACES IV Gasoline Formula produces significantly more efficient use of engine compression out of the same volume of untreated fuel which provides more power/torque. Effective use of BTU values from the same fuel volume. Especially good for engines that are extremely efficient such as turbo and supercharged applications.
Fuel Tank and Gasoline Delivery System Protection – Our fuel catalyst contains pour point depressants and low temperature characteristics that improve fuel flow at very cold temperatures. It has a negative affinity or repelling characteristic that resists fuel from turning to ice and the wax inherent in the fuel from plugging fuel filters and fuel lines.
FLAME FRONT ENHANCING COMPOUND - The major improving characteristic of this compound is increasing the engine's ability to burn the fuel it normally receives more efficiently
CONSERVATION OF ENERGY - E=Q+W. Total Energy equals the quotient of expended heat + the appreciable work. This produces more horsepower, torque, better throttle response and smoother running. Also better cold weather operation as well. Better utilization of BTU.
PRODUCES UPPER CYLINDER LUBRICITY AS A REACTION TO HEAT - produces a high technology post combustion lubricity to change the cylinder environment with plentiful lubricant created by the heat itself. Cylinder components have tested to be between 4 to 8 times more lubricated than with base fuels alone especially with Ethyl Alcohol laced ultra low sulfur gasolines.
ANTI-CORROSION PROPERTIES - characteristic stops oxygen and formic acid mixed combustion deposits from allowing damage to fuel systems and cylinder componentry.
PRESSURE WAVE DYNAMIC INCREASE WITHIN CYLINDERS - This modifies the flame speed allowing more fuel to be burned at a more expansive rate during peak heat release so as to continue the burn beyond normal available atmospheric oxygen producing power and efficiency.
GUM AND VARNISH CONTROL - Copper, vanadium and sodium can produce gum and varnish due to the combustion process especially Ethyl Alcohol fuels . We have a designed component that deactivates this process which will stop gum and sludges from occurring not only in the fuel system but in the upper stem and guide area which rob performance due to white hot activation due to turbo heat.
MOLECULAR BALANCING TECHNOLOGY - Takes base fuel characteristics and makes them uniform or 'synthetic" in structure allowing fuel to burn cleanly and without after run or detonation.
These are the different compounds we combine in our product that makes our materials unique compared to any other "additive".
Regards,
Brian
BND Automotive LLC
440-821-9040
www.bndautomotive.com
