ACES IV - An effective octane booster and anti-wear additive?
Started by SHOdded, August 05, 2015, 04:58:25 AM
ecoboostsho
I'm 95% confident (hey I could be wrong!) that there isn't an Octane sensor.  Perhaps someone who really knows can chime in.  From everything I've seen LOR is "inferred" based on the engine's ability at different throttle positions to not knock.  If it can advance timing and not see knock at various load levels then it "assumes" that you must be running a higher octane fuel and it will advance the LOR so you get to run more timing.  If it sees too much knock then again the ECU assumes you've put in some craptastic gas and moves the LOR in the appropriate direction.
If that is how it works then ACES would HAVE to prevent knock to enhance LOR since that is the only way it can affect it.  There might be other variables involved with LOR though but again I don't think an actual Octane sensor enters in to the picture.  That said I have no idea what ACES claims to do so I can't comment.
It would not surprise me if the car paid particular attention to knock and adjusting the LOR value right after you fill up.  That would trigger the algorithm in the ECU since you obviously just put new gas in.
I am basing most of observations off of this article:
http://www.cobbtuning.com/ford-ecoboost-and-the-octane-adjust-ratio-monitor/
Dxlnt1
Quote from: ecoboostsho on December 11, 2015, 09:23:25 AM
Im pretty sure you are right about lack of actual octane sensor. And I know we splitting hairs here, but you can't put the cart before the horse. The LOR has to be seen BEFORE timing can be adjusted. A crappy LOR and no knock present nets more timing. But hi number of knocks and a superior LOR nets less timing. If ALL of the "protective" features built into the ECU are calculations, inferred, or theoretical any glitch in the primary sensor (there would have to be at least 1 physical sensor) used for calculation, the ECU fail to safe mode and NOT run. Theoretically.
I also don't believe throttle position directly affects ANY performance parameter. That is a calibration and variable used for fuel delivery/demand. (I guess that does affect performance huh lol). 100% throttle and inadequate fuel delivery or rail pressure per flow curve nets engine cutting power. Theoretically!
I have seen this on my GMC when throttle position and throttle body doesn't calibrate properly at startup. So it disables the drive by wire and truck becomes useless until reset.
All of the sensors and calibrations are part of a HUGE formula to determine and dictate load and demand.
There is no octane sensor. Octane is merely a fuels resistance to knock.  The car uses algorithms based on raw ks output combined with deductive fuel logic to determine fuel composition and octane.
No octane sensor in these cars, knock-inferred only.  You get "fuel composition" sensors if Ford originally built the vehicle to run E85 or otherwise be an FFV.  Examples of such sensors are Ford Part 9C044-AA and 9C044-BA, made for the FFV Ranger 3.0L engine.
P0178 Description
Fuel Composition Sensors are used to determine the amount of ethanol alcohol in the gasoline. Normally, a gasoline engine should not have more than 10% ethanol alcohol in the fuel for proper operation. Some vehicles have a Flexible Fuel (FF) system on them that allow them to run on up to 85% ethanol alcohol in the fuel. The fuel composition sensor sends a frequency modulated signal to the engine controller which is proportional to the alcohol content of the fuel. The injector pulse width and the ignition timing are modified for the increased alcohol content. It takes almost twice the amount of alcohol compared to gasoline to produce the same power.
Read more: http://www.helpforcars.net/obd_codes/p0178.html
Dxlnt1
AND you realize there is no knock sensor either! Only a microphone listening for certain frequencies in exhaust. As I stated the fuel is NOT changed but the ignition curve is modified.
http://stratifiedauto.com/blog/understanding-knock-and-ignition-corrections-in-your-high-performance-ecoboost-engine/
Scott4957
Quote from: Dxlnt1 on December 11, 2015, 02:24:55 PM
I think this is something that many people new to tuning do not realize and should be pointed out in a "about tuning" sticky. I sometimes see people obsessing over some random KR event, they need to realize that road noise, a bump in the road, road debris etc can set off the knock sensor. I do my pulls the same place every time, imagine if there was a bump in that road and I was not aware it was the cause of a KR event LOL.  Its one of many reasons you can get a better tune on the Dyno.
2013 Lincoln MKS EcoBoost, AJP Tuned
Quote from: Scott4957 on December 11, 2015, 02:35:20 PM
I disagree with that last statement completely.  Data logs and timeslips are highly effective over a much broader range of operating conditions.
Scott4957
That's true. A better tune is not necessarily one that makes peak power. I should have said you can make peak power "just a number"
ecoboostsho
Well there IS a knock sensor...it just happens to be a microphone. Agreed on random KR events though.  I used to have knock spikes at the shift in a previous car but determined that it was just the noise from shifting setting off the "knock" sensor.  That said knock sensors and the software that processes the signal have gotten significantly better at identifying these types of events.  I trust mine. ;)
"Modern cars such as the one above have well tuned "microphones" called knock sensors that pick up on these sounds and react very quickly to stop detonation when it starts. The 4 cylinder Ecoboost in the Focus ST has two of these little guys."
Quote from: ajpturbo link=topic=5087.msg88967#msg88967 date=1449 883839
My civic has 4 !...
AJ you mean 4 cylinders right.lol  Z    ;)
Little bit off topic but there is also a RRD Rough road detection system to eliminate false misfire indications due to the road condition,the RRD uses data from the ABS Wheel speed sensors for estimating the severity of the rough road.  Z
Quote from: ZSHO on December 12, 2015, 05:55:53 AM
My civic has 4 !...
Hell no...4 knock sensors.....one for each cylinder lol
The Japanese DO know overkill, wouldn't put it past them :)
