H&R's after about 200 miles.
Started by ElvenSho, August 02, 2015, 07:13:06 PM
ElvenSho
The ride is good but I think I need to get an alignment done as soon as possible since my front tires seem to be making more noise for some reason even tho the car does not pull to any side. Performance wise the car feels like it gets off the line quicker with less weight transfer and also takes the turns better for sure.
What kind of noise and when does it happen, elven?
ElvenSho
Quote from: SHOdded on August 02, 2015, 08:16:50 PM
It just sounds like tire noise. Happens when cruising on a highway or even around town. Everything was installed correctly and it does not make noise over bumps or when turning. The noise is hard to explain but its tires making it. I ch3cked the tires and they will need replacing in the next 20k miles or so.
Alignment is a must when lowering.
Screaming tires = alignment time
Thought I was ok after my coilover install...I was wrong, even though the car went straight.
Rich
ElvenSho
Quote from: SHOnUup on August 06, 2015, 09:12:40 AM
Rich
Yup they are screaming a lot, the bad thing is I just took a trip that will be about 1000+ miles long and I didnt have a chance to get an alignment until I get back. The good thing is the tires quiet down going 65+ which I have been doing. The tires will probably need replacing after this trip, it does not pull to any side.
Quote from: ElvenSho on August 06, 2015, 09:56:46 AM
Rich
I had about a 1,000 miles on before my alignment & new tires...wore one of the rears slightly more, but not awkward wear for some reason...just more
Rich
