Started by curry67, August 01, 2015, 05:11:43 PM
Quote from: curry67 on August 02, 2015, 02:31:30 PMSo would thst explain higher knock readings on higher octane? Sent from my SM-N910W8 using Tapatalk
Quote from: ajpturbo on August 02, 2015, 02:39:21 PMQuote from: curry67 on August 02, 2015, 02:31:30 PMSo would thst explain higher knock readings on higher octane? Sent from my SM-N910W8 using TapatalkMaybe....But you really need to have someone verify on a log just to make sure that's really what you have. Then I would want to look for trends....5 and 6 is a little high...If it's an isolated event then no biggie. If it continues then your timing tables need work and are over advanced and you are relying on the knock sensors.Take your device and under user options retard the spark by 4 or 6 degrees and see if it's better...If it is then your spark tables are over advanced.I like my knock sensor readings to be like my short term fuel trims.....They should hover around 0. A little above and below is good.
Quote from: curry67 on August 02, 2015, 02:42:24 PMQuote from: ajpturbo on August 02, 2015, 02:39:21 PMQuote from: curry67 on August 02, 2015, 02:31:30 PMSo would thst explain higher knock readings on higher octane? Sent from my SM-N910W8 using TapatalkMaybe....But you really need to have someone verify on a log just to make sure that's really what you have. Then I would want to look for trends....5 and 6 is a little high...If it's an isolated event then no biggie. If it continues then your timing tables need work and are over advanced and you are relying on the knock sensors.Take your device and under user options retard the spark by 4 or 6 degrees and see if it's better...If it is then your spark tables are over advanced.I like my knock sensor readings to be like my short term fuel trims.....They should hover around 0. A little above and below is good.Even on stock tune? Sent from my SM-N910W8 using Tapatalk
Quote from: SHOdded on August 02, 2015, 11:52:22 PMMake a note of any rattles or ticking noises you hear at any time. Want to eliminate cam phaser/timing chain involvement. What motor oil/filter are you running, BTW?
