Incorrect AFR at WOT Help!!
Started by kskrew4life, July 26, 2015, 08:59:14 PM
Quote from: kskrew4life on July 27, 2015, 04:29:33 PM
Quote from: SHOdded on July 27, 2015, 12:05:12 PM
Excellent idea!  Wait till you feel the SHO has settled back into the stock tune, then datalog.
How long do you think the ECU takes to relearn after a flash?
I can tell you the trims like 45 min to an hour minimum.
Not sure if this helps, but this is what was posted some time ago here.
The torque obd drive cycle widget will tell you when its complete iirc....
kskrew4life
Quote from: glock-coma on July 27, 2015, 10:09:17 PM
GREAT Thanks! this will definitely help.. it seems if all steps arnt completed in the same session it gets interrupted and starts over.. i was logging some data earlier.. this probly explains why it looks so screwy.
kskrew4life
Quote from: FoMoCoSHO on July 27, 2015, 10:15:07 PM
I have the Torque OBD app, didnt know there was a drive cycle widget. I will  look that up, that could come in handy whenever i flash a new tune.
I think its called the status monitor.....
When you press and hold for the add gauge function, scroll through all your options and I think it's in there....
kskrew4life
i found two widgets one says "Drive cycle status since DTC clear" and "Current Drive cycle status" thanks for pointing this out :)
kskrew4life
i captured a WOT session with the stock tune... the afr numbers look really off.. can someone confirm if i need to replace both o2 sensors based on this log? i still dont feel anything unusual with the car im at a lost whyt eh readings are so off,
You mean the lambda numbers?  Those are afr as a percentage of stoich for your fuel.  For example 14.7 for gasoline.  So lambda of 1 would be equivalent to afr of 14.7.
Havent looked at the two most recent logs yet.  In the midst of an emerrgency system rebuild.
kskrew4life
Quote from: SHOdded on July 28, 2015, 02:00:11 PM
Havent looked at the two most recent logs yet.  In the midst of an emergency system rebuild.
Yes i was looking up a lambda conversion chart but there was no entry above 1.405 lambda which translate to 20.66 afr... the last log is showing max at 2.00 !! with an average of 1.2.. those are really high values yet  there is no check light, no knock, nothing out of the ordinary as for as driving.
Kscrew, that is where you lifted and the car went into decel fuel cutoff which is normal.
You will also see high numbers as you transition in and out of that mode as well......
kskrew4life
#28
Im using the SCT x4 device with the liveLink Gen-II. Torrie said both sensors in the log were not responding correctly, I have no idea what is going on
kskrew4life
Quote from: FoMoCoSHO on July 28, 2015, 02:43:36 PM
Thats a relief, i was kinda worried about that. thanks for explaining that
