Quote from: nickstewartroc on June 10, 2015, 09:17:34 AM
Quote from: Dxlnt1 on December 21, 2013, 11:22:36 PM
Full Alpine system installed. Replaced door speakers with Alpine type r. Installed 2-10" subs type s in trunk. Factory amp used to power factory subs and surround speakers. (Front & rear deck).
Head unit is Alpine INE-W927HD. Killer unit. Killer features. Killer sound. This unit much faster than previous Kenwood units I used.
Scosche adapter kit makes everything flow seemlessly in cabin. Looks like factory install. Scosche could have done better to match panel colors but overall looks great. Because of this I can't do gage pod install now maybe by summer.
The screen about the climate controls, was that from the SHO before install? I bought the same Scoshe kit, but my SHO has nav...
Thanks!
This is the before pic and after pic. The factory NAV will go away. As the purpose of this unit is to replace OEM head unit. SO you will lose factory NAV, and SYNC as that is all controlled and interfaced through the head unit. And yes, has video bypass to allow playing of video while car in motion.
Alpine INE-927 HD, As for video inputs, this particular units video is via 3.5mm plug which gets used in conduction with usb. An adapter meshes them together for iPod 30 pin, but can be split apart for any video. Can probably add this adapter to make it easy for just video input.
The newer model (Alpine INE 957 HD) has same connections, but adds HDMI video input. The HDMI does NOT support sound so you will have to use the usb connection for that. But very doable. I am considering swapping the 957 model from my truck to install into SHO. Mainly for the HDMI but also notice the music icon is larger on 957.
As for the value, I have a classified ad on here where I was considering selling my current sub boxes. Either with or without the speakers. (Type S Alpine). I was going to have 12" subs installed. So if anyone is interested in these boxes, let me know. Make a reasonable offer and I will consider it. But I have system tuned to sound great now. But the 12"s would make it awesome!
