July 28, 2021, 06:32:10 AM
Author Topic:  "Complete" List of TSB's for your 2010-2012 SHO  (Read 63407 times)
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
Re: "Complete" List of TSB's for your 2010-2012 SHO
« Reply #30 on: November 02, 2016, 04:13:29 PM »
Whether you have Ford or non-Ford warranty you have to check what your warranty covers.    TSB is independent of warranty coverage, it is simply a service bulletin advising techs what to do in the event of that particular issue occurring.  Sometimes Ford does extend warranty on parts/repairs in a Customer Satisfaction Program, like brake booster, APIM, etc.  But this is rare.
Offline FearlessAZ
  • Just Another Dirty Desert MKS
  • Sr. Member
  • Phoenix
  • -Given: 593
  • -Received: 153
  • Liked:
  • Likes Given: 23
« Reply #31 on: November 02, 2016, 04:19:31 PM »
Ahhhh I see. So the TSB is more of a how to/guide on some symptoms and fixes. I was more under the impression that it was kind of like a recall.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #32 on: November 02, 2016, 04:23:25 PM »
Then it would have said "Recall" :)  But yes, a TSB is a how to/guide.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #33 on: December 10, 2016, 06:33:14 AM »
TSB 14-0105   3.5L GTDI DIAGNOSTIC TROUBLE CODE (DTC) P0087 – BUILT ON OR BEFORE 6/1/2014
FORD:   2012-2014 Flex, Taurus; 2013-2014 Explorer
LINCOLN:   2012-2014 MKT
ISSUE:
Some 2013-2014 Explorer, 2012–2014 Taurus, MKT and Flex vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 6/1/2014 may exhibit a rough idle and/or DTC P0087 after a hot engine restart.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS or Ford J2534 release 90.03 and higher. Calibration files may also be obtained at www.motorcraft.com.
NOTE: ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE’S COMPUTER TO LEARN THE TRANSMISSION’S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS.
OPERATION   DESCRIPTION   TIME
140105A   2013-2014 Explorer, 2012-2014 Taurus, MKT, Flex 3.5L GTDI: Retrieve DTCs, Reprogram The PCM Includes Time To Clear Codes (Do Not Use With Any Other Labor Operations)   0.3 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO.   CONDITION CODE
RECALEM   04
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #34 on: March 16, 2017, 04:05:43 AM »
2007-2016 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police – AWD – Ticking/Knocking Noise From Driveline – Built On Or Before 30-Jun-2016
Some 2007-2016 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police equipped with All Wheel Drive (AWD) and built on or before 30-Jun-2016 may exhibit a ticking and/or knocking noise coming from the driveline area.
To identify this noise, refer to Workshop Manual (WSM), Section 100-04, and follow the symptom chart.
If the source of the noise is identified as the PTU and/or internal to the PTU, disassemble PTU assembly.
Refer to updated WSM, Section 308-07. If the PTU is determined to be repairable, utilize kit GB5Z-7P258-A and the included instruction sheet.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #35 on: March 30, 2017, 03:34:39 PM »
TSB 10-2-6  AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION, NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS
FORD:
2010 Taurus, Flex
LINCOLN:
2010 MKS, MKT
ISSUE
Some 2010 Taurus, Flex, MKS and MKT vehicles equipped with an EcoBoost engine may have unauthorized aftermarket modifications to the powertrain hardware and/or calibration which may result in exceeding component design limits. Such modifications could cause damage to the powertrain and/or void the factory powertrain warranty.
ACTION
Review Service Procedure
SERVICE PROCEDURE
Unauthorized calibration modifications may or may not be detectable using standard tools (Integrated Diagnostic System (IDS), Portable Diagnostic Software (PDS), NGS+ VCM). Changes can be made to the calibration and flashed to the PCM through the OBD port. Physical modifications to the hardware may or may not be present. If aftermarket power/torque-increasing modifications are suspected, care should be taken to record and store the following items: Permanent Diagnostic Trouble Codes (DTCs), Pending DTCs, Freeze Frame Data, Mode 6 and Mode 9 data. The data should be printed and attached to the repair order for later reference.
The DTCs, freeze frame data, Mode 6 and 9 data can be obtained by using the IDS, PDS or NGS+VCM under tool box selection. The Powertrain tab will provide the OBD Test Modes tab and Mode 6 and 9 data selection after the vehicle has been identified.
Attempting to increase the engine output via recalibrating the PCM may result in poor drivability, DTCs, or component failures. A partial list of calibration induced component failures is given below:
^ Piston damage.
^ Spark over-advanced (knock-induced damage).
^ Insufficient enrichment.
Excessive Cylinder Pressure:
^ Turbocharger damage.
Over-Speed:
^ Catalyst damage.
Over-Temperature/Melting:
^ Transmission, PTU, Torque converter damage.
Hardware Modifications:
The following list contains items that are frequently modified in an effort to increase the engines torque/power output. Modifying these items may, or may not improve the performance, but can lead to drivability issues, DTCs and possibly component failures:
^ Air induction system (air box, low pressure and high pressure air ducts).
The system may be particularly susceptible to flexible air ducts between the air filter and the compressors. Restrictions on either side of the compressor can result in over-speeding the turbo (Figures 5-6).
^ Wastegate actuator pre-tension.
The full load output of some turbocharged engines will increase if the wastegate spring pre-tension is increased. This is not the case with the EcoBoost engine. Adjusting the wastegate pre-tension out of the specified range can result in DTCs. A tamper evident paint dot has been applied to the wastegate actuator adjustment mechanism to make modifications more apparent.
^ Throttle inlet and intake manifold pressure sensors.
These sensors and the associated wiring should be inspected to verify they have not been modified.
^ Additional fuel injection devices.
The high pressure fuel system used for the EcoBoost engine will not support additional fuel flow beyond what the factory calibration requests. Inspect the engine for an additional aftermarket injector(s) located somewhere in the induction system to provided increased fuel flow.
^ PCV system modifications.
If the PCV system is modified (vented to atmosphere being the most common modification) it can result in a condition where oil gets past the turbine seal even on an undamaged, fully functional turbocharger. Oil in the exhaust system may not be sufficient evidence to identify a failed turbo if the PCV system has been compromised.
^ Compressor bypass modifications (a.k.a. blow-off valve, or anti-surge valve).
It is common to modify these components so they make more noise. If the aftermarket devices fail to seal properly when closed, elevated turbo speeds and compressor outlet temperatures will occur.
^ Exhaust air path/system.
Removal of catalysts or mufflers/resonators to reduce exhaust backpressure may result in over-speeding the turbo(s).
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #36 on: May 14, 2017, 12:10:18 AM »
February 27, 2017 MANUFACTURER COMMUNICATION NUMBER: SSM 46412 - PTU
Components: POWER TRAIN, EQUIPMENT
NHTSA ID Number: 10095858
Manufacturer Communication Number: SSM 46412
Summary
SOME 2007-2016 EDGE/MKX/FLEX/MKT/MKZ/MKS/TAURUS/TAURUS POLICE/EXPLORER/EXPLORER POLICE EQUIPPED WITH ALL WHEEL DRIVE (AWD) AND BUILT ON OR BEFORE 30-JUN-2016 MAY EXHIBIT A TICKING AND/OR KNOCKING NOISE COMING FROM THE DRIVELINE AREA. TO IDENTIFY THIS NOISE, REFER TO WORKSHOP MANUAL (WSM), SECTION 100-04, AND FOLLOW THE SYMPTOM CHART. IF THE SOURCE OF THE NOISE IS IDENTIFIED AS THE PTU AND/OR INTERNAL TO THE PTU, DISASSEMBLE PTU ASSEMBLY. REFER TO UPDATED WSM, SECTION 308-07. IF THE PTU IS DETERMINED TO BE REPAIRABLE, UTILIZE KIT GB5Z-7P258-A (PTU Idler Gear Repair Kit, about $315) AND THE INCLUDED INSTRUCTION SHEET. FOR CLAIMING, USE CAUSAL PART 7P258 AND APPLICABLE LABOR OPERATIONS IN SECTION 07 OF THE SERVICE LABOR TIME STANDARDS (SLTS) MANUAL.
77 Associated Products
Vehicles
MAKE           MODEL   YEAR
FORD    EDGE             2007-2016
FORD    EXPLORER     2007-2016
FORD    FLEX             2009-2016
FORD    TAURUS     2007-2016
FORD    TAURUS POLICE INTERCEPTOR    2013-2015
LINCOLN    MKS             2009-2016
LINCOLN    MKT             2009-2016
LINCOLN    MKX             2007-2016
LINCOLN    MKZ             2007-2016
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #37 on: June 14, 2017, 10:13:12 AM »
SSM 44856 - Various 2011-2015 Vehicles - Cruise Control Speed Setting Display May Not MatchSpeedometer
Some 2013-2015 Fusion, Taurus, 2011-2015 Explorer, 2013-2014 Edge, Flex, 2013-2015 Lincoln MKS, MKX and 2013-2014 Lincoln MKT, vehicles may exhibit a cruise control speed that does not match the speedometer speed. The Instrument Panel Cluster (IPC) provides a tolerance which allows the speedometer gauge to display between 3% lower and 7% higher than the actual vehicle speed. This means that with an actual vehicle speed of 96 kmh (60 mph), the speedometer may indicate between93 kmh (58 mph) and 103 kmh (64 mph), which is normal. Refer to Workshop Manual(WSM), Section 413-01 Description and Operation, Instrument Panel Cluster (IPC). If you are outside of this tolerance range, refer to the WSM for normal diagnosis.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4088
  • Liked:
  • Likes Given: 0
« Reply #38 on: June 14, 2017, 10:50:32 AM »
-MANU Great INFO as always. Z :thumb: :thumb:
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #39 on: March 06, 2018, 04:09:30 PM »
SSM 47119 – 2011-2018 Explorer/Police Interceptor Utility/Police Interceptor Sedan Taurus/Flex/MKT and 2011-2016 MKS – 3.5L EcoBoost – Engine Assembly Replacement
During 3.5L EcoBoost engine assembly replacement, inspect the color of the positive crank ventilation (PCV) camshaft cover adaptor located next to the high pressure fuel pump on the original engine and compare to the service replacement engine.
The adaptor color of the service replacement engine must match the original engine.
If the adaptor on the original engine is green, install a green adaptor (HL2E-6762-AA) on the service replacement engine.
If the adapter is removed from the camshaft cover, damage will occur to the adapter locking mechanism.
Make sure detached pieces of the locking mechanism do not fall into the open port during removal.
APPLICABLE VEHICLES
2013 – 2018 EXPLORER
2011 – 2018 FLEX
2011 – 2016 LINCOLN MKS
2011 – 2018 MKT
2011 – 2018 TAURUS
Offline 5ohSHO
  • Full Member
  • Fort Worth, TX
  • -Given: 39
  • -Received: 111
  • Liked:
  • Likes Given: 0
« Reply #40 on: March 06, 2018, 11:41:13 PM »
I always wondered about that. Thanks for the info.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #41 on: July 07, 2019, 06:33:49 PM »
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #42 on: August 31, 2019, 08:30:41 AM »
TSB 10-22-4 AWD VEHICLES - SHUDDER-CHATTER-VIBRATION ON TURNS OR THUMP-CLUNK NOISE ON LIGHT ACCELERATION - BUILT 10-1-2009 TO 12-31-2009
Replace the PTU
Offline rdmccrary
  • Newbie
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 0
« Reply #43 on: June 18, 2021, 08:55:54 AM »
Replace the PTU
I know this is an older thread, but all the effort to put it together helped me to help my local Ford dealer complete a diagnosis and get the proper work done.    Thanks to those of you that worked on this list.  Dennis
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #44 on: July 07, 2021, 07:08:47 AM »
attached pdf for 10-22-4
* Recent Topics
Re: New from Minnesota...
by PDSHO | July 27, 2021, 04:15:43 PM
Re: Ol' Guy in New England........
by PDSHO | July 27, 2021, 04:13:04 PM
Re: Random Pull/Torque Steer after new moog lower control arms.
by mystery101 | July 26, 2021, 08:44:32 PM
Today I went to a different dealer for an alignment. They spent 3 hour...
Re: Terrain Management System Fault - wrench light
by EcoHell | July 22, 2021, 09:21:04 PM
Yes and this was on a 2015 SHO. She sat 3 days if I recall. Fri Sat S...
Re: Any advice on how to improve 1/4 mile times?
by ridered74 | July 20, 2021, 01:20:55 AM
I appreciate your guys replies, i have both GH and Ortiz tunes. Lately...
Re: 15 Interceptor Sedan Ecoboost with GHT Tune - Engine Coolant Overtemp
by Ta2dResqr | July 19, 2021, 09:30:11 AM
When was the last time coolant was changed? It does break down over ti...
Re: Part numbers needed for rocker panel retainers...
by 6500rpm | July 11, 2021, 05:41:29 PM
Results-...
ecoboost_xsport Consolidated Build/Maintenance Thread
by Ecoboost_xsport | July 11, 2021, 05:28:32 PM
So, haven't been so active lately, but still lots of stuff moving...
FREE Goody Bag Swag for Your Car Show
by RockAuto | July 08, 2021, 04:08:40 PM
RockAuto would love to work with your upcoming car show, cruise-in, sw...
Second Custom Tune Free with Programmer Purchase + SCT $40-$45 Summer Rebate
by tmcphail | July 08, 2021, 01:08:47 PM
Purchase an SCT or HPTuners Programmer with 1 Custom Tune and receive ...
