Took a look at doing a front mount...
Started by EcoPowerParts, June 29, 2013, 11:47:41 AM
FaSSt9602
Quote from: 4DRHTRD on June 30, 2013, 02:46:55 AM
Quote from: Boggus on June 29, 2013, 10:02:07 PM
So since you are creating new piping, can you install an aftermarket BOV instead of using the oem units?
That's the plan eventually but I don't have enough straight pipe or a welder to do that.
I finished everything except for the bottom pipe from the front turbo to the IC, too many compound bends and size change in a short tube. I'll have to get that done later.
I'll take some pictures in the morning. It hit 119+ today so it was a bit HOT in the garage.
Mike, I've got a 220v mig welder you can borrow.  I have a cord that you can use to plug into your dryer outlet....
Edit...NM, I see you have aluminum tubing.  I don't have a spool gun for it...
2010 EB Flex Limited Dark Ink Blue Metallic/White Suede two tone
Sadly it is the wife's car, so I can't go too crazy on it...just a simple tune for now.
Hey Mike!  How's the plumbing job coming along?
Quote from: DJE624 on July 06, 2013, 11:33:36 PM
I gave up and  took it to the shop to do a few things for me. I'll post up info after.
Sent from my phone with lots of misspelled words...
Shonuff1140
So the AC does in fact disengage under WOT? I always suspected it did, nice to know for sure now.
FaSSt9602
Quote from: chad1140 on July 08, 2013, 02:45:28 AM
Yes it does,  and here in AZ it sucks because it blows really hot for a few seconds. :-[
Sent from my mobile gizmo
Gray Brick
2013 Ecoboost Ford Flex
derfdog15
Quote from: Gray Brick on September 20, 2016, 11:52:19 AM
What happened to this project?
Seconded, id prefer an Air-to-Air FMIC but this may be an option as well. But its been so long since an update!
Gray Brick
Is this project dead?
I am in the process of the same build.
Welding in fittings for the MAP and methanol on the new water to air intercooler to throttle body.
