Took a look at doing a front mount...
Started by EcoPowerParts, June 29, 2013, 11:47:41 AM
I pulled off all of my hot side piping today between turbos and IC and IC to TB to get them redone in silicone and thought while I was crawling around if there would be a way to replace the existing IC with a new front mount.
Well short answer is NO.
That being said I'm going to start looking at putting a water to air intercooler under the hood.
In order to do that it will require doing a new air intake to the turbos and then replace the piping to the intercooler and then over to the throttle body.
Probably going to take some time though as I'll have to remove my 1 gallon fuel cell under the hood which means that I'm waiting on parts from Squash Performance for the dual in tank fuel pumps.
I'm going to try and get the hot side stuff replaced and then get the turbos dyno'd before I tear it down and take it off the road for awhile.
YAY more parts to develop! :)
Not only pictures, but any particular sizes as well.
Maybe if we both badger Samco Staff enough, they'd be inclined to produce some type of kit for our applications?
**still waiting on Kirk's return call btw (since you mentioned new intake).
Sent from my DROID3 using Tapatalk 2
Just picked up all the silicone tubing, aluminum u bends and now at home depot picking up a band saw. :D
Sent from my phone with lots of misspelled words...
You're cheating using a band saw Michael.....
Challenge yourself & do it manually with a coping saw.
Boggus
Interested as well, would love to upgrade my lines on the hot side.
2013 unleashed SHO PP
Quote from: bpd1151 on June 29, 2013, 04:17:23 PM
Nope, I want to do it right :)
Instead of paying labor I'm starting to just buy more tools. :)
You can do it right with a coping saw. Which is cheaper to purchase than a band saw, and then in turn double your savings in both labor & tool purchases! :ok:
Quote from: bpd1151 on June 29, 2013, 05:06:50 PM
I can't cut aluminum pipe with a coping saw. I could use a hack saw but this will be much cleaner and be needed when I build my intercooler setup
Boggus
So since you are creating new piping, can you install an aftermarket BOV instead of using the oem units?
Quote from: Boggus on June 29, 2013, 10:02:07 PM
That's the plan eventually but I don't have enough straight pipe or a welder to do that.
I finished everything except for the bottom pipe from the front turbo to the IC, too many compound bends and size change in a short tube. I'll have to get that done later.
I'll take some pictures in the morning. It hit 119+ today so it was a bit HOT in the garage.
Quote from: 4DRHTRD on June 30, 2013, 02:46:55 AMI'll take some pictures in the morning.
Holy high hell! I was just watching the weather / news last night, & they were reporting how blistering hot it was / has been, out by you 4DR.
Jeezuz bro..... mid 115's to low 120's during the day.... with some areas having overnight lows still in the mid/upper 90's!
'Tis no wonder your stock plumbing/hose work is splitting all over the place.
My goodness!
Have to learn NOT to use your A/C in those temps when driving for extended periods!  Now that's fun :D
bnoon
Yeah air to water is pretty much the only way. I want tiny filters om the turbos, then BIG air to water core. Should be good time.
Quote from: SHOdded on June 30, 2013, 02:47:16 PM
I just let my AC turn off all by itself when I got WOT, no way to drive around with no A/C and windows up here you'll die pretty quickly from heat exposure.
