What should I do next / kill story
Started by scoles92, June 08, 2015, 02:22:34 PM
Quote from: scoles92 on June 08, 2015, 10:27:03 PM
Torrie did my tunes. I think he said his tunes add up to 60hp to the wheels. Will a water meth kit really give me that much of a gain?
I believe it. I would trust Torrie. He definitely knows what he's talking about.
2010 RCM non PP
K&N panel filter with aux hose
RX OCC with CSS
sp534 @ 30
unleashed tune 12.90@106
On my previous 2013
Stock - 13.79
Stock +E25 - 13.31
Torrie 3 bar and E85 tune - 12.66
scoles92
#17
I'm not arguing what Torrie told me. I could tell I gained a lot the second I drove it. What I'm asking is could I really gain 60 to the wheels with a meth kit? How safe are these kits?
2011 ford Taurus SHO PP  unleashed tunes, 3 bar, plugs,K&N intake, stage 3 water meth.
scoles92
I mean if these kits a are safe and I can get upwards of that much power I'll buy one  and get a before and after dyno done. Anybody have that snow stage 3??
Quote from: scoles92 on June 09, 2015, 11:49:28 AM
40 -60 would be my guess with the benefit of a safer operating environment and clean valves.
Wilson
Yup,  I gained 10hp just spraying meth,  no tune. Gained right around 50hp total at the wheels after the meth tune.
I've got the Snow Stage 2 kit. I'm not sure if anyone here is running the Stage 3 kit. If they are,  I must have missed it.
Wilson
2013 SHO (non-PP) Ruby Red Tintcoat
Leading Edge Tuning 93 Tune | 3 Bar MAP | 170* Thermostat | Airaid Intake | PPE 2.5" Downpipes | Snow Stage 2 Meth Kit | H&R Lowering Springs | 22" Falken RT-7M wheels | 265/35/22 Falken Ziex TZ05 tires
Wilson
Looking back I wish I would've done meth before downpipes,  but it all worked out in the end.
Wilson
Sabtaj1
I have the stage 3 snow kit. It's not totally installed yet.  I didn't want to use my washer fluid tank so I am mounting the tank and pump inside the front bumper and I bought the fill res. from alcohol injections along with a #10 nozzle. I have a flex by the way. Not sure if there is a huge diff between the 2 and 3. But it's nice to have the controller on my steering column and read the boost there and can adjust it on the fly. I also have DP's waiting too. Just haven't had much time lately :-(
13 Eco flex.
Is the stage 3 for DI cars now also?  At this time last year, it was for EFI only.
N/M, found the DI product page:
http://www.snowperformance.net/Stage-3-Boost-Cooler-Water-Methanol-Injection-Kit-p/320.htm
65fastback2+2
methanol just increase the detonation capabilities of gasoline...in other words, when using it, you can add additional timing that you otherwise couldnt.
scoles92
Thanks for the info guys it's looking more and more like that's the route I'll go. Just as long as it won't blow my car up haha. Still can't believe how much downpipes cost!
65fastback2+2
theres always the chance if the system malfunctions.
one of the most reliable meth kits on the market: http://www.alkycontrol.com/
Quote from: 65fastback2+2 on June 09, 2015, 06:10:21 PM
And in the case of the fuel challenged 3.5, it also adds fuel enrichment.
65fastback2+2
correct, methanol is fuel. which is why you have to be careful with it, if your supplemental fuel system has an issue, you instantly go lean.
brooklynsho
#29
What year is your car? 2010-2012 should upgrade brakes to 2013 booster&master cvlinder ,brake pads rotors or any combination of the above  as buget allows  if ya going to play on the street you gotta Make shure you can STOP!!
2011 white  fastlane turbo cai ppe catted down pipes magnaflow cat back,unleashes 3 bar tune 170 t stat  ngk plugs irange colder  2013 booster& master cylinder upgrade
