X2,So many variables to take into consideration,would just keep monitoring it on frequent intervals,like SHOdded mentioned a good obd port scanner such as proscan is highly recommended for more sufficient overall readings,it is also important to make sure that the trans is at normal running temp before performing any wot runs,or it will emit high KR(knock retard)readings,you can always revert back to stock tune to monitor for any changes,did you install the 160 stat at the same time as the tune?good luck and keep us updated. Z
