Engine Specs:
- LSX Block
- All-Pro Heads with oversized Titanium intake valves and Nitronic exhaust valves
- FAST Intake Manifold
- Nick Williams 102mm TB
- Callies Magnum Crank
- Callies Ultra XD Rods
- Ross custom piston with low compression (9.5:1 for turbo application)
- Meziere WP
- Katech Oil Pump
- Aviad dry sump baffle
- Comp Lifters
- Custom cam
- Cometic head gaskets
- Cloyes billet timing chain setup
Drivetrain:
- RPM Level 6
- RPM Level 3 Rear Diff
- DSS Carbon prop shaft
- RPS Twin Billet Carbon Clutch w/Flywheel
- 300M Axles
- MGW Short shifter with Box
