Started by 14 TUX BL, April 10, 2015, 11:15:50 AM
Quote from: ZSHO on April 15, 2015, 10:42:25 AMThe answer is very simple without the back and forth discussions which clearly sounds gratifying to you based on your other post,there are plenty of options like trading in your non-PP for a PP just like i did,hope this helps you out.
Quote from: IHeartGroceries on April 15, 2015, 11:31:16 AMYou bought a sport lux car, with wonderful power. As if having no manual trans option isn't bad enough, if the inability to defeat traction control really isn't a problem, that's incredible! That's like having the world's fastest supercomputer with no mouse or keyboard to use it! Lol
Quote from: Dxlnt1 on April 15, 2015, 01:08:45 PM... Someone posted on this thread the top end for PP was 122 mph and Non as 140 mph.
Quote from: SHOnUup on April 15, 2015, 03:36:40 PMThanks...maybe this is the reasoning behind the gearing change? PP models are all 20" wheels right?Rich
Quote from: SHOnUup on April 15, 2015, 11:55:44 PMIf this is all about performance, shouldn't there be a tuned side to the debate. The majority of us are running tunes here. I'd just like to hear some thoughts on that side of the spectrum. Like downsizing wheel size and stuff to add sidewall flex for grip. And, is turning off the traction control completely better vs just turning off the grannies, assuming that's what us non pp folk do.Not trying to discredit your, what I see as a great open minded thread of discussion. Just adding another dimension. Rich
QuotePopular MechanicsChrysler 300C AWD vs. Ford Taurus SHOSep 30, 2009http://www.popularmechanics.com/cars/a12885/4322127/Chrysler 300C AWDBase price $39,925Powertrain 370 hp/398 lb-ft, 5.7-liter V8, 5AWheelbase (in.) 120.0Length (in.) 196.8Width (in.) 74.1Axle ratio 3.07Weight 4280Brakes (f/r) 12.6-in disc/12.6-in disc, ABS, ESCTires (f/r) P225/60R-18ACCELERATION (sec)0-30 mph: 2.00-60 mph: 5.50-100 mph: 13.940-70 mph: 4.220-60 mph rolling start: 4.4Quarter-mile: 13.9 @ 100.3 mphBRAKING (ft.)30-0 mph: 30.460-0 mph: 126.2EPA fuel economy (city/hwy) 16/23 PM Fuel Economy 21--------------------------------------------------------------------------Ford Taurus SHOBase price $37,995Powertrain 365 hp/350 lb-ft, 3.5-liter V6, 6AWheelbase (in.) 112.9Length (in.) 202.9Width (in.) 76.2Axle ratio 2.77Weight 4368Brakes (f/r) 12.8-in disc/13.0-in disc, ABS, ESCTires (f/r) P245/45R-20ACCELERATION (sec)0-30 mph: 2.20-60 mph: 5.40-100 mph: 13.340-70 mph: 4.920-60 mph rolling start: 4.2Quarter-mile: 13.7 @ 101.7 mphBRAKING (ft.)30-0 mph: 29.960-0 mph: 117.6EPA fuel economy (city/hwy) 17/25 PM Fuel Economy 22
Quote from: 14 TUX BL on April 17, 2015, 08:52:48 AMIn a way, it doesn't figure ...The 300C Hemi makes 5 more hp, 48 more lb-ft, weighs 88 lbs less, and has better gearing. Yet it was slower in 0-60 mph, 0-100 mph, 20-60 mph, 40-70 mph, the quarter mile, and had worse braking.
Quote from: FoMoCoSHO on April 17, 2015, 09:11:08 AMQuote from: 14 TUX BL on April 17, 2015, 08:52:48 AMIn a way, it doesn't figure ...The 300C Hemi makes 5 more hp, 48 more lb-ft, weighs 88 lbs less, and has better gearing. Yet it was slower in 0-60 mph, 0-100 mph, 20-60 mph, 40-70 mph, the quarter mile, and had worse braking.It's all that torque at 1700 rpm. Plug your dragstrip numbers into a 1/4 mile to hp converter and you will see what I mean.
Quote from: SHOnUup on April 17, 2015, 09:37:53 AMQuote from: FoMoCoSHO on April 17, 2015, 09:11:08 AMQuote from: 14 TUX BL on April 17, 2015, 08:52:48 AMIn a way, it doesn't figure ...The 300C Hemi makes 5 more hp, 48 more lb-ft, weighs 88 lbs less, and has better gearing. Yet it was slower in 0-60 mph, 0-100 mph, 20-60 mph, 40-70 mph, the quarter mile, and had worse braking.It's all that torque at 1700 rpm. Plug your dragstrip numbers into a 1/4 mile to hp converter and you will see what I mean.For sure...our HP #'s get horrible estimated times. Then I plug in times to get HP and it's up around 500 hp. Rich
