Quote from: jmr061 on August 28, 2015, 05:29:25 PMYes they tease you with it not to mention goes to prove that Travel Link etc can be enabled in post factory navigation setups that are done properly.
Quote from: BiGMaC on August 28, 2015, 05:35:14 PMQuote from: jmr061 on August 28, 2015, 05:29:25 PMYes they tease you with it not to mention goes to prove that Travel Link etc can be enabled in post factory navigation setups that are done properly. I love the travel link when I'm on the road... However even though the trial is enabled if you don't renew after the 6 month trial it likely will quit since Sirius sends a code from their server directly to your car to enable the regular subscription telling the APIM you're current.
Quote from: jmr061 on August 28, 2015, 06:08:07 PMQuote from: BiGMaC on August 28, 2015, 05:35:14 PMQuote from: jmr061 on August 28, 2015, 05:29:25 PMYes they tease you with it not to mention goes to prove that Travel Link etc can be enabled in post factory navigation setups that are done properly. I love the travel link when I'm on the road... However even though the trial is enabled if you don't renew after the 6 month trial it likely will quit since Sirius sends a code from their server directly to your car to enable the regular subscription telling the APIM you're current.Just to clear things up the Sirius satellite receiver is in the ACM (audio control module aka cd player which houses the AM/FM receiver as well). The APIM only is a display for the Sirius Radio.
Quote from: FoMoCoSHO on August 29, 2015, 09:33:21 AMGreat Vids thanks!Those should clear up some of the misconceptions about gen 4.2 AWD. (max power transfer, etc)
Quote from: FoMoCoSHO on August 29, 2015, 09:53:04 AMhttp://www.ford.com/fordpoliceinterceptor/features/#/durability/durability_05/So they have this instead of the cover with none of the high speed issues?I will take one with a side of ballistic door panels, lol
Quote from: BiGMaC on August 29, 2015, 10:52:31 AMGood info Z.... Also glad you're finally getting that windshield... And that the supply chain appears to have caught up with demand.
