I had to get an "aftermarket" windshield from safelite. That glass looks the same, has the same dot matrix pattern and tinting on the top, just a different name on it.
Although, I had a horrible experience with safelite and will never use them again. First they ordered the wrong windshield so I had to go in to the safelite shop for the install of the aftermarket glass. I asked the installer if the rain sensor worked and he said he sprayed the glass and it work. He lied to my face as the sensor wasn't even hooked up, just dangling in the rearview cover. They sent a mobile installer out to fix that but they didn't replace the sensor pad. A few days later it rained and the wipers intermittently worked on the auto setting. Then I go to spray my windshield and no water is spraying. I get home, fill up the reservoir and spray again and see the water pouring out under the car. The sumabish installer didn't even hook up the water lines! Oh, and they put scratches on my dash during the install.
They're coming later this morning to fix the sprayers and I'm getting my $425 reimbursed.
