Random thoughts for the day
TopherSho
If it is the true bug eye,  that glass built transmission wont last the winter.. that WILL quiet him down.
Best 0-60 public road 4.35s
Scott4957
Just use a broomstick to shove one of those tailpipe whistles way down inside his exhaust  pipe.
https://youtu.be/kiEMa_oWXz0
Sent from my SM-G955U using Tapatalk
2013 Lincoln MKS EcoBoost, AJP Tuned
Macgyver
Quote from: StealBlueSho on September 12, 2018, 08:05:09 PM
Just a rant....
My neighbors son purchased a bugeye WRX.... it has been modded.... along with an extremely load fart can...he drives through the neighborhood like a jackass...  he revs is up every time he passes my house so I get to hear his BOV and exhaust popping all day long since he doesn't work.... and he gives me the stink eye....
I was getting ice cream for the Misses a couple nights ago... on the way home I see his ass driving and we meet up at a red light and I'm in my SHO... he looks over... I figured with all his stink eyes and reving he would actually step up... NOPE... won't run me....
I did ask him on Facebook if he wanted to see what he could do at a racetrack... meet up and have some fun... maybe settle him down a bit... NOPE....
For the record he is 19...
End rant...
Doesnt work but buys a car ?
StealBlueSho
Quote from: Macgyver on September 13, 2018, 02:12:19 PM
Just a rant....
End rant...
He got some money from the National Guard I believe and his dad paid for half. Could be wrong, but yea... not sure how that happened to begin with.
I was curious if anyone noticed there MPG Decrease in the last week or so!!!
I'm thinking maybe winter-blend gasoline is upon us!!! Dunno!  Z  :hmmm:
I think you are right!  Although I am currently running a bottle of Techron CP through the tank and mpg usually goes down a good bit during that time ...
StealBlueSho
That why Ethanol is awesome... not for the MPG of course...
I was speaking with SHOdded personally on adding a couple of new sections on Forum board! Stay tuned. Z   :)
802SHO
Quote from: 802SHO on September 15, 2018, 09:44:13 PM
Suspensefull!  Need 🍿
Need to get a bigger bucket! Lol. Z  :D
:popcornandbeer
ToMang07
Quote from: ZSHO on September 13, 2018, 06:02:07 PM
I actually just recorded my best-ever MPG this tank.... 21.7 MPG!  Previous best was 21.4 but that was all interstate driving.
(I'm attributing this to the consistently cooler temps, not fuel quality.)
~Tom~
2013 SHO - Stage 3 Snow Performance Meth, (2) SCT X4 with Unleashed, 3 Bar Map, MSD Ignition Coils w/Colder Plugs 170*TS, EcoPowerParts Hot Pipes & Tial-Q BOV) Stage 3 Motorsports Catless Downpipes 3" Cat-Back Exhaust, JLT Oil Separator, H&R Sport Springs, K&N CAI, Drilled and Slotted Rotors w/EBC Pads
I noticed after a couple hundred miles of highway driving I'm back up to 18.1 mpg for the time being!
I initially found it odd that in matter of a few days it dropped from 16.8 to 16.0 with mostly city driving which was a bit odd !
The SHO runs better and stronger than ever with absolutely ZERO Codes.  Z
StealBlueSho
When you have two Ecoboost powered vehicles.... you set priorities...
Has anyone tried the NGK 97177 LTR6CI-8 Laser Iridium Plug!  Z
Laser Welded Tips
Trivalent Metal Plating
Longest Life Available
Gap: .031" (0.8mm)
Center Electrode
Material: Iridium
Type: Fine Wire
Projection: Projected
Ground Electrode
Material: Platinum
Type: Standard
Quantity: 1
Specifications
Warranty: 1 Year
Torque Specs: Cast Iron: 10.8-18 lb. ft. Aluminum: 7.2-14.5 lb. ft.
Brand: NGK
Heat Range: 6
Longevity: 100k Miles
https://www.ngk.com/product.aspx?zpid=40565
It looks like www.rockauto.com has the best price of $8.27 - ea
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,ignition,spark+plug,7212
https://www.rockauto.com/en/moreinfo.php?pk=6572356&cc=1503823&jsn=471
