Random thoughts for the day
griggs95
Quote from: bpd1151 on February 19, 2018, 01:29:27 PM
#WINNING !
Nice price...and 93 to boot, I'm jealous. 91 is my best option.
Is there any other thing besides gas that 9 tenths of a cent is acceptable? It's really $3.01 you're paying...funny.
2011 pp: lms 91 tune - ppe downs w/ kitties - Amsoiled myself all around - gapped 30 sp plugs - enthused driver, nervous passengers - aem drop in dry filter.
Quote from: stealbluesho on February 19, 2018, 03:14:05 PM
The shell by my house has terrible 93.... I always get some part throttle KR with it... sheetz has better gas my way.
Shell 93 is pretty consistent near me.  87 is variable.  If I go north 20 miles, gas is better regardless of station.  No idea why.  Safeway 87 up there >> Shell 87 down here lol.
I guess after a bit of research found that the Motorcraft air filter has a 98.5% efficiency standard which is about average for a standard filter.
I believe the Mahle air filter has a 99.5% filtration rate which is not to shabby IMO!  Z  :)
I have always used Mahle and Hengst on my Bmw and Benz with awesome results.
http://www.mahle-aftermarket.com/na/en/products-and-services/filters/air-filters/index.jsp#airfiltersforpassengercars
http://www.mahle.com/en/products-and-services/passenger-cars/cooling/
http://www.mahle.com/en/products-and-services/passenger-cars/air-management/turbocharging/charge_air_cooling/index.jsp
MAHLE Drive With The Original 1000HP Mustang Twin Turbo Engine Build At Petty's Garage
! No longer available
Well they say a dirty filter is more efficient than a clean one ... To a point.  I would recommend the Filter Minder, but it hurts the bling factor a little bit, plus where to install on a CAI?  LOL.  Does save on unnecessary filter changes.
Quote from: SHOdded on February 19, 2018, 06:08:04 PM
Off Topic but curious on how much black soot if any will be alleviated with the stock CAI & better paper Filter!  Z
Better flow/oxygenations seems to be the key.  MDesign CAI and ethanol both have affected this change, ethanol to a greater degree.  possibly due to soot washout, but IDK.
StealBlueSho
My car is the king of soot... and I have no idea why... personally I don't really care...
It's only bad at start up... and usually only after I flash while the trims get adjusted...
Wish I had a stock airbox to compare...
Quote from: stealbluesho on February 19, 2018, 08:40:19 PM
That's the very reason I put the stock intake back to see if there is any notable difference in soot!
I know there is a history of black soot formation even from new ecoboosts sitting @ the dealerships but only to a certain extent!
I think the black soot is contributed to the aftermarket intake IMO due to it not sealed up properly but could be wrong!  Z
StealBlueSho
Quote from: ZSHO on February 19, 2018, 08:58:38 PM
I think the black soot is contributed to the aftermarket intake IMO but could be wrong!  Z
Has there been any noticeable difference? Curious...
I just assumed it was the excess fuel being dumped out the tailpipes during a cold start... maybe the CAI filter is causing it run rich? Not sure when the car switches from open to closed loop..
Quote from: stealbluesho on February 19, 2018, 09:00:43 PM
Sometimes if the Air intake is partially obstructed it will cause a rich mixture! or the TB! I know some have reported less black soot with the MDesign But so many variables to consider!
It's only been a couple hundred miles with the stock intake but will surely monitor for any changes!  Z
StinkinLinkin13
Try going completely cat-less.... I can't park within a few feet of the garage or else two black splatters. Like getting inked by two octopuses. 😋
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
LOL @ "getting inked by two octopuses".
Ha!
 Calamari with some fresh garlic and olive oil! Good quicker upper! Lol. Z   :D
StealBlueSho
Couldn't find my 10mm socket... and now... the whole garage is cleaned and tools are organized... found 3 of the 10mm sockets... I know there are more hiding..
