Random thoughts for the day
Started by EcoPowerParts, June 26, 2013, 09:50:08 AM
SM105K
Quote from: ZSHO on July 01, 2019, 06:21:14 PM
I'm hoping to finally have some time to install these! Been Too darn busy as of late!
It might also make for a nice memorabilia! Z   :D
YES DO IT! LOL.
802SHO
Quote from: SM105K on July 02, 2019, 09:53:27 AM
YES DO IT! LOL.
You didn't do that yet?  Jeez what else you got laying around that isn't installed yet?  Long list probably ...
76fomoco
Quote from: 802SHO on July 02, 2019, 10:26:29 AM
YES DO IT! LOL.
might think about new 1st spot O2's while your in there...
2013 PP AJP E30 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 3-29-21  11.85 with 3000 DA
DA trap best 117.96
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
Quote from: 76fomoco on July 02, 2019, 10:32:25 AM
YES DO IT! LOL.
The GH-IC and A/C Condensor consumed much of my resources as the DP were had long before the IC! I will be adding New gaskets-Studs-bolts and new 02 sensors to the DP install!
BTW the MODS never end! Lol. Z
SM105K
Yep the MODS never end, and the SHO must go on.
76fomoco
as one of my buds said "you just can't step away from the parts counter can you?"
:toilet_claw:
DA trap best 117.96
YES DO IT! LOL.
True indeed! I ordered a set of the Motorcraft DY-1184 Front primary wide-band 02 sensors which are a bit longer than the OEM DY-1185 and one Down-steam Front and one Down stream 02 sensor! New DP comes new accessories.
Here are some PICS for comparison. Z
shoNoff
Z why are you changing the pipes?
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Quote from: shoNoff on July 02, 2019, 05:04:38 PM
They lost bit of their luster over the years here in N.Y.  Z
Guess who was secretly visiting me today and did not even tell me :P :P :P
Quote from: SHOdded on July 02, 2019, 06:32:02 PM
Ha Ha Nice find! It looks like a Non-PP! Z
:o :/ :(
Yours is SOOOO much better looking!  Still, brought up good memories :D
Quote from: SHOdded on July 02, 2019, 07:42:39 PM
:o :/ :(
Definitely gotta meetup once again! Z  :)
I left the SHO parked @ the local Walmart to find a sizable ding on the Driver's side door!  >:(
Its unfortunately at a bad spot right under the door handle which unfortunately cannot be pulled out! Darn scoundrels! Z
SM105K
#3734
Sorry to hear that Z. I just sent the below pic to a paintless dent repairman so I feel your pain. I now park the furthest away from everyone possible.
