Random thoughts for the day
Started by EcoPowerParts, June 26, 2013, 09:50:08 AM
StealBlueSho
I will not be giving me SHO back... they can go pound sand...
Agreed!!!
SM105K
I Don't mind if they compensate me with a Brand spankin new SHO in RED of course! Lol. Z  :D
StealBlueSho
Quote from: ZSHO on April 29, 2019, 10:43:38 AM
Hmm maybe if they pay as well to swap over all your performance parts? You have quite a bit invested into yours...
SM105K
Quote from: StealBlueSHO on April 29, 2019, 10:46:41 AM
Come on now Z, they aren't VW!
True indeed! Mods are documented with receipts and all!
August will be 6 years with 64K on the OD! Dunno! Z
To the ^^^ So many Good memories with the Redhead and still have the Original Key Fob untouched and Vehicle Build certificate etc as memorabilia and a Best Trap Speed of 115.54 mph last Fall! She's a Keeper! Z   :)
sholxgt
FWIW, I went from beating any "EPA" fuel economy rating in the '80's-'00's to being lucky to be able to achieve the rated fuel economy.  I think all manufacture's have been basically stretching the truth since 2010 or so.  As a family, we've owned a bunch of stuff so I truly think it's all brands.
MiWiAu
Swapped out my winter wheels today and noticed something peculiar. Is it just me, or is one pipe lower than it should be?
I don't remember there being that much "flex" in the flex pipe to the front cat...
2013 XSport
Quote from: MiWiAu on May 04, 2019, 03:10:19 PM
It could be the Rubber Insulator which holds the Flex pipe in place! Z
https://fordpartsgiant.com/parts/ford-insulator-rubber_5f9z-5f262-aa.html?Make=Ford&Model=Explorer&Year=2013&Submodel=&Filter=(30275)
MiWiAu
Quote from: ZSHO on May 04, 2019, 04:14:08 PM
I'm hoping this is just another dealer screw up from when they pulled my engine for the timing chain replacement. I'll try to loosen everything up and re-clock the pipe to see if I can get it straight before buying additional parts.
Thanks for the heads up! :)
2013 XSport
MiWiAu
Luckily, I was able to just loosen the flange bolts at the cat, lift the pipe into place, and retighten the flange. Seems to be correct now. Glad I caught it before ripping. It off on a curb. :) #attentiontodetail
2013 XSport
Quote from: MiWiAu on May 04, 2019, 04:38:56 PM
It sounds like the Bolts were recently removed by the dealer! Mine were a Pita to remove! Glad you caught it in time. Z   :)
