Random thoughts for the day
Started by EcoPowerParts, June 26, 2013, 09:50:08 AM
I just picked up a Craftsman 2.5 gal. Corded Wet/Dry Vacuum 1.75 hp @ my local Ace hardware for a sweet deal of $19.99
I figured I'll pass on the savings. Z  :)
https://www.acehardware.com/departments/tools/wet-dry-vacuums/wetdry-vacuums/2305696
irondoor19
Quote from: ZSHO on August 10, 2018, 01:48:15 PM
What can you Get for 21 bucks, Not Much, thanks again
Quote from: irondoor19 on August 11, 2018, 01:34:48 PM
NP Bud! enjoy.  Z   :)
Has anyone tried changing your water to coolant ratio since Optimal Coolant Ratio Depends on Your Climate for added benefits....
FWIW I was thinking of a 70/30 water-to-anti-freeze mixture and prior to winter switching back to 40-60.
Here's a good article below.....
Since the lowest freezing point is achieved at a 40/60 water-to-anti-freeze ratio, there's no added benefit to using more anti-freeze. Therefore, if you live in an area that will never see less than 26°F, your car's performance will most likely be optimal at a 90/10 ratio year round.
If you live in an area that can see temperatures as low as -10°F in the winter, but can also get to 95°F in the summer, then you're better off running a 60/40 ratio. However, if you're one that may get stuck in traffic with the air conditioner on during the summer months, you may want to make the switch to a 90/10 ratio until winter hits again to get the most out of your car year round.
Make sure to read your vehicle's owner's manual to find the coolant system's capacity so that you can figure out how much anti-freeze to add!
https://www.ngk.com/learning-center/article/653/quest-for-the-ideal-coolant-ratio
NITSOOB
Definitely thinking of going 90/10 out here in this Sunny SoCal weather
2013 PP SHO - 3.5" DPs, 3.5" Exhaust, 3" Coldside
Pending: 5-Blade billet wheel, AJP Tune
1/8: 8.4@86
Gjkrisa
Only thing with that high you may start to see rust
Quote from: NITSOOB on August 15, 2018, 06:55:26 PM
Gjkrisa
Quote from: Gjkrisa on August 18, 2018, 01:58:42 AM
Just got this in my newsfeed
http://www.underhoodservice.com/ford-3-5l-ecoboost-common-problems/
Its funny they mention a solution they found online it to drill a 1/16"hole in your CAC (Intercooler). THIS PROCEDURE CAN CREATE A LEAK IN THE SYSTEM!! HA!  Z
StealBlueSho
Quote from: ZSHO on August 18, 2018, 07:06:26 AM
Yup! But it don't try to argue that point with the F150 crowd... they get all pissy!
Quote from: StealBlueSho on August 18, 2018, 08:47:23 AM
Its simply not supported on this Forum! Z
For anyone dealing with stuck boots when changing plugs, a bit of PBblaster or wd40 can help in removing them.
