Quote from: MDesign on March 31, 2015, 11:57:14 AM
To chime in though, the MDesign intake uses the OEM intake air inlet just as the OEM system does and the probability of water entering the intake is just as likely with the OEM intake. The OEM intake has no drains, it is a sealed unit just as all (if not all then most) OEM manufacturers intakes are designed and MDesign intake is designed.
Ok, so there was a bit of misinformation pertaining to the factory intake box here that I want to clarify:
#1 I took a look at my factory intake last night from my 2014 SHO and it DOES have three drain holes at the bottom of the box. Two are under the intake itself and 1 where the outside inlet meets the factory inlet box. See picture below:
#2 Outside inlet has two 90 degree bends. where any water would have to hit before it hits the filter element. By then, it would drain out the bottom. See picture below:
#3 Pertaining to the water concern, I'm assuming Ford put holes in the intake box for a reason. If you take a look at my intake box, it shows clear signs of water & other outside elements from that inlet.
#4 Where I stand corrected, there is no DIRECT path for water to get into the intake. The hood seal closes off the front inlet, however, water can still get through the bottom radiator portion at highway speeds. The front radiator has a rounded piece that blocks direct water from making it into the inlet. See below:
I am still not 100% convinced that the MDesign still doesn't need a fail safe for water. I love the look, but I don't believe that water never makes it into the sealed canister; I think that is a bold statement given the drain holes in the factory box... My factory box shows that water makes it into the intake box...
Thoughts?
