Quote from: jtoddk98 on March 19, 2015, 03:00:08 PM
Quote from: mistadobalina on March 18, 2015, 09:17:00 PM
I got them installed. The fronts took about 2 minutes, but the rears took quite a bit longer. It's not a hard install, though.
Difference between LED's and Stock:
All lights installed, viewed from drivers door:
All lights installed, viewed from the back seat:
how'd you do the back seat lights? I just got my full led kit, even replaced the tail light bulbs with super bright led ones
I pried the dome light out using my fingers. Pull down from the back side sitting in the back seat, and you'll be able to wiggle it out. Unplug the power, and it comes all the way out.
Then there's 4 small screws to get the white part off.
After you remove that, there's 4 small screws per side bulb. Take those out and you can remove the bulb assembly. There's then two more small screws to take the bulb out of the dome type thing.
When you unplug the old bulbs, take note of the direction they came out. Orientation matters because of the thin wires at the connection.
After you get the two side bulbs and assemblies out, you can push the clear center light cover off and swap that bulb out too.
Replace all 3 bulbs with the LEDs and plug it in prior to screwing all the small screws in to make sure the lights work.
Reverse for re installation.
