- RotM Winner
- Elite Member
- Boosted
- Logged
PTU results of same interval ..about 2k miles and same fluid, Redline Lightweight Shockproof gear oil. Glad I changed it out. I'll be tapping the PTU to add a drain plug, so I can do a proper flush and rule out left over wear-in from contaminating the rest results. Confident to see better results next time.
