Wheel hop/motor mounts?
Started by Stuntz, February 15, 2015, 01:47:32 PM
I think those coilovers are calling for you Rich ;)
Quote from: ZSHO on February 16, 2015, 08:40:10 AM
They are....
Cats have been the only ones to enjoy them yet.
Rich
Stuntz
Quote from: TSS on February 16, 2015, 08:04:33 AM
I had what I described as  a 1-2 stutter under  WOT .  Can you describe wheel hop to me? Perhaps its the same thing I was experiencing.
I just got a B&G transmission fluid change, rear differential fluid change, coolant change, and PTU fluid change.  I can't swear by it, but the runs I have taken so far, only two of them, there was no shudder/sutter. It's too cold here to really test right now, but I'm going to continue testing to see if somehow, with those preventive maintenance items, it went away.
When I hit 2nd at wot it shudders which I'm describing as wheel hop. It comes from the front and it feels like the front is hopping up and down as it spins.
Unleashed Tuned, Airaid, 3 bar, 170 t-stat, H&R Springs
TSS
I think We all are describing the same thing. I thought it was transmission based, but wheel hop makes sense too. it doesn't happen with the stock tune when there is significantly less power being delivered. And it doesn't happen except for wide open throttle position from first to second.
wasinger3000
Yep. Happens to me too. You could soften the shift from 1-2 and see how it does.
13' GTCS, will be missed.
Stuntz
I softened the 1-2 shift last night but it's in the 20's this morning so not going to be trying any hard launches today.
Quote from: Stuntz on February 17, 2015, 09:25:19 AM
Good move....been awhile here since I've attempted a full launch also.
Rich
ElvenSho
I noticed this happens to me also now with Unleashed tune. I am pretty sure its wheelhop as it doesent happen when my tires actually spin only when there is more traction. It depends what street i am on.
I just quit mashing it from a dig all together until it warms up. The hop is atrocious in any ambient temps lower than 50 or 60. Least ways, with the OE Goodyears.
2013BlackSHO
I am experiencing the exact problem!
It started as soon as I got my Unleashed tune...
I've had Torrie change the 1-2 shift twice but still feel it most times at WOT.
I have what's left of my factory Michelens with 42,000! (I know)
Really hoping this is a Wheel hop issue, I'm terrified my transmission is in trouble!
Torrie 93 3-Bar tune
Quote from: 2013BlackSHO on April 27, 2015, 07:20:55 PM
Have you serviced the trans at all?
Rich
