Virtual Dyno explained
Started by EcoPowerParts, June 21, 2013, 10:11:53 AM
This is a place holder for info on Virtual dyno and how we can utilize it for our cars by using SCT logs and 3rd or 4th gear pulls on a flat road to review our HP.
Why would you use this? If you're using a mail order tune you can take data logs for the tuner that will allow them to see what your car is doing. If you are playing with timing you want to get to a place where more timing doesn't add more power, you can only see this with a dyno. By utilizing this program you can get the car really close what the maximum output possible without spending HOURS for dyno time. After you think you're close THEN you head to the dyno to do some verification pulls. I'm getting my car dyno'd this week with the new turbos, I'll go out and do a log afterwords and do a comparison. Heck I'll do a log on the dyno for a comparison! :)
Vehicle tech specs:
Flex/SHO/Explorer Sport transmissions ratios
1 4.481:1
2 2.87:1
3 1.84:1
4 1.41:1
5 1:1
6 .74:1
R 2.88:1
Final Drive 3.16:1
SHO PP
Final Drive 3.39:1
F-150
1 4.17:1
2 2.34:1
3 1.52:1
4 1:14:1
5 .86:1
6 .61:1
R 3.40
Final drive options:
3.15, 3.31, 3.55, 3.73
Weight options:
SHO weight 4224
Flex weight 4781
Explorer Sport 4921
RCLB 4x2 4938
RCLB 4x4 5140
SCABSB 4x2 5374
SCABSB 4x4 5564
SCREWSB 4x2 5287
SCREWSB 4x4 5625
SCREWLB 4x2 5492
SCREWLB 4x4 5745
Frontal Area (these numbers look WRONG but can't find good info):
Flex 25sq ft
SHO 28.95 sq ft
Explorer Sport 20 sq ft
F-150 36 sq ft
Drag Coefficient
Flex .355
SHO .32
Explorer Sport (can't find it)
F-150 .416
Download Virtual Dyno here:
http://www.virtualdyno.net/
These are things I've researched for my car, we'll be adding all the other platforms information as well.
I will also do a video on how to use the program as soon as I can, need to get the car back from the shop first.
Virtual Dyno facebook page:
https://www.facebook.com/VirtualDyno
Another how to on Virtual Dyno:
http://forums.evolutionm.net/evo-dyno-tuning-results/619146-how-use-virtual-dyno-properly.html
http://youtu.be/SSY2ohtHiIw
http://youtu.be/1THnCP5vxvU
http://youtu.be/pZWVHAhE77o
http://youtu.be/3c2pN06oPlM
I am attaching a Ford Flex profile I built. I will also create a video to show you how to use it. The video will work for SCT csv file.
EcoBrick Bob
I thought the 2010-2012 non-PP SHO had a 2.73 & the PP SHO a 3.16.   Is the 2013 different?
Since I am running smaller diameter tires which change my axle to an effective 3.40, do I have to adjust everything by the tire diameter difference?
Naples, FL & Clear Lake, IA
Quote from: EcoBrick Bob on June 21, 2013, 11:50:02 AM
You can edit the tire size.
If I have the wrong info then I can change BUT I got it right from the Ford Specifications list here:
http://media.ford.com/images/10031/2012_Taurus_Specs.pdf
EcoBrick Bob
I could be wrong, but that may be the non-turbo vehicle.
Added some how to videos in the first post. Bob if you can show me tech spec to confirm the SHO final drive I'll update.
I also need frontal area and drag coefficient for the SHO so I can make an XML file for it.
Added SHO.zip which has both PP and non-PP configurations (final drive 3.16 vs 3.39)
If this is wrong I can update later.
StrawHatShinobi
Played around a bit with this tonight, my final numbers were a little disappointing compared to what it spit out the first go around (3800+ HP/5000+tq)  ;D
I logged a 3rd gear run and ended up/with 399 HP 460ish TQ
'13 Eco screw FX4 - THE56 turbos, AEM Dry flow, MAK DP, 4" exhaust, meth injection, Walbro 450 lift pump, 2"HBS level, 20" Fuel Nuts on 33" Toyo M/T's
Quote from: redsand on June 22, 2013, 02:15:59 AM
That's what I would expect on an F-150.
EcoBrick Bob
Quote from: 4DRHTRD on June 21, 2013, 05:16:16 PM
I see you didn't change it yet.
I'm at the dyno doing work! >:D
Sent from my phone with lots of misspelled words...
breeves002
You can do virtual dyno runs with ScanXL too. Never gotten around to doing it, but I know its possible. Of course I'd rather get a real dyno than a virtual one.
SHO Lover and Advanced Diagnostics Enthusiast
2008 Mercury Sable Premier - 3.5L N/A Duratec
FPO
I have the App "Dash command", I had to enter data , ( like weight ect)
So I do not  know how accurate it is.
The one thing I do know the dealer must  must of had 87 in it, because I got better results on the next tank (93)   this was from that tank.
Quote from: FPO on October 05, 2014, 10:18:35 PM
what did you enter for bsfc?
paokara777
I started playing with this app yesterday, very cool! Interesting results.
Has anyone confirmed that the final gear on a SHO is in fact 2.73 & the PP SHO a 3.16 and not the ones in the XML which are 3.16 and 3.39
Daily Drive:
2010 Ford Taurus SHO, AJP 3BAR 93, K&N drop in
Weekend Cruiser:
1968 Ford Mustang Coupe 289 C Code
4Bl Carb, HiPo Cam, Headers and Exhaust
