Why the livernois thermostat & map sensor
Started by moem1090, January 22, 2015, 10:57:12 PM
moem1090
Hey guys, just wondering if anyone has done the thermostat and map sensor from any other manufacturer and had good success? Just curious
2013 Roush Stage 3: Supercharged & Ready to Go Fast
2010 SHO - Daily: Corsa Cat-Back, Roush CAI, LME Downpipes, LME 3-Bar, LME Thermostat, LME Tune 4+
The 3bar map sensor is the same part that all vendors and dealers carry,the t-stat is a must if your car is tuned for better performance with plugs,there are two sets of stats,there is the Reische 170 stat and the 160 stat which i heard is somewhat better than the 170 stat,which i have,mine came with the gasket and coudnt be happier,the 160 stat does not come with the gasket,you have to use your existing one or buy a new one,good luck.
J-Will
The 3 bar map sensor is a Ford part and requires a tune to work on our cars.
T-stats are a common swap in vehicles. LME doesn't make theirs, they are a retailer. They are the ones that simply found the t-stat that fits our engine.
Edit: I stand corrected, please see response below
3-bar
SP-542 plugs w/ GH gap
Livernois Motorsports
Quote from: J-Will on January 23, 2015, 07:50:44 AM
They are actually our part, we are not a retailer.
J-Will
3-bar
Glassman710
i know when you return to stock you have to switch out map sensor, what about the 170 thermo? can u drive it stock with that still installed
2013 SHO with Performance Pack, SunTek CXP 18% Tints, Corsa Cat Back Exhaust, K&N Drop in filter, Unleashed 93 octane 2 bar tune. 12.75 @ 107.71 @ palm beach raceway, Florida DYNO JET 346.27 WHP 385.95 WTQ
I have been driving on and off with a tune for a while know,have the Reishe 170 stat also and you should not have any issues,same goes for the plugs if there gapped at 0.30.
