I did the typical grill mod...
Started by FLOSHO21, January 31, 2015, 08:44:13 PM
FLOSHO21
I was able to use factory clips, just cut a slit in the mesh and push it on. Then I epoxied it on the clips, and used a couple self tapping screws  on the corners just in case.
2010 SHO Platinum non PP
H&R springs, K&N panel, NGK-6510, 170 T-stat, Unleashed Tune, 3 bar, 13' MC/booster, Unleashed 3" DPs, W/M
12.74@108.5 3/15
8.07@86.5 best 1/8th 9/15
southtxSHO
Where did you but the SHO emblem for the grill ? Having a hard time finding it . Can only find the one that goes on the trunk
2011 SHO non PP
LMS 4 +tune
LMS Cai
LMS catted downpipes
12.89@ 105 MPH best time @ Edinburg Raceway
Quote from: southtxSHO on February 24, 2015, 02:05:00 AM
Looks like it's the c-pillar S-H-O
Rich
The SHO I have on my grill is the rear emblem with the economist part removed.
southtxSHO
Quote from: crash712us on February 24, 2015, 09:07:11 AM
Probably going with that size , since  it stands out more. Thanks
2011 SHO non PP
LMS 4 +tune
LMS Cai
Tomc612
I used a heat gun on low or a blow dryer will work..some Goo-gone and the c-pillar SHO came off. Then used Meguiar's Ultimate Compound & polish to clean up the c- pillar. I figured since I have the front side fender SHO emblems on my 2010..I felt that displaying ''SHO'' twice on each side wasn't necessary and was aiming for a clean "stealthy look"
