10' SHO Oil smell
Started by Quinid, January 26, 2015, 02:02:07 PM
PCM recalibration might do the trick.
markssho
Quinid - there is a TSB about it randomly dropping into neutral. I can't find it right off, but that happened to me. Another symptom is that the rear backup camera sometimes activates.
They replace the range shift indicator for that TSB.
Quinid
Thought I'd give an update.  So the smell came back and i dropped it off for an oil change.  Told them to look at the turbo again.  When i picked it up they claimed there was random oil on the cat.  So they washed it off. I glared at him and said,  "So you are saying it will come back. " he replied,  "well we hope not"
Wow. Confidence in ford is gone. ..
2 weeks later the smell came back but is now so strong going down the road it gives me and the mrs a headache. And just last night i could suddenly near a bearing whine with that random nasty vibration wobble noise a bad bearing makes. The pitch goes in accordance of road speed but the noise level does not go up or down in left or right turns.    I think that extended bumper to bumper is about to pay itself off.
2014 Blue Flex 303A Appearance package all stock
2000 F250 XLT 7.3L 410k miles
SOLD--2010 nonPP SHO  Unleashed 93 tune, 3 bar map, K&N drop in filter. PPE Catted Downpipes. VTA mod
1957 Chevy 3200 pickup 3 speed stock straight 6
1968 Camaro RS 3 speed 350 sb with vortec heads.
Quinid
As far a neutral drops go.  I have not had one since January and they still refuse to fix that unless it occurs in front of their mechanic..
Check your PTU fluid. It may be coming out of the vent and leaking down. The whine may be the PTU gears due to loss of fluid.
Quinid
I wondered that too. I made them change the fluid in January. I'll bring it up. Thank u
Quinid
Called the dealership Saturday and the dealership can  not get me in until next Monday.  And on the commute today that bearing or whatever just gave out.  The cars driveline just started shuttering.  The engine is fine but cv joint? Transmission? Oil smell went strong again right when it happened. Gotta get towed...
I think glock had it nailed with his PTU diagnosis for this issue.  Could be RDU, but odds are PTU.
Quinid
Should i give the tow truck driver any special instructions? Like flatbed it? Or the normal way with letting the rear tires roll on the pavement?
flatbed is best.
From the OM:
On AWD vehicles, it is required that your vehicle be towed with a wheel
lift and dollies or flatbed equipment with all the wheels off the ground to
prevent damage to the automatic transmission, AWD system or vehicle.
If the vehicle is towed by other means or incorrectly, vehicle
damage may occur.
Ford Motor Company produces a towing manual for all authorized tow
truck operators. Have your tow truck operator refer to this manual for
proper hook-up and towing procedures for your vehicle.
Quinid
Best of luck on a quick fix.
Rich
Quinid
Lol thank you.  I have a spare car but its a 1957 chevy truck with a top speed of 60 with a whopping 90hp. Not exactly ideal for interstate use lol
More fun than a Smart Car though?
