Warped Rotors @ 50K miles
Started by liteyouup, January 24, 2015, 11:11:41 AM
liteyouup
Took the Explorer to California last week, and was getting some shaking while coming down the mountain, only while braking, worse when pushing harder.  I assume I need new rotors... anything other than normal pads/rotors I need to keep an eye out for?  Do we have like known caliper problems or anything?
2013 Explorer Sport
...and on that day, not one #@%$ was given.
Do you have original pads on your X SPORT? there is TSB but that is pertaining to the rear pads having corrosion buildup between the pad and anchor bracket causing brake squeak,depending also on the dealer,personally would try to make an appt with your service advisor and maybe they would consider it under warranty,especially if the truck was purchased new from the same dealership.  http://www.carcomplaints.com/Ford/Explorer/2013/tsbs/
Definitely sounds like warped rotors. Have to remember the key to braking down a decent incline is to brake pretty good at times over riding the brakes. Huge heat build up when riding the brakes down a hill.
Rich
liteyouup
I don't ride the brakes but hard to say how the wife drives when I'm not around.
I bought it used @35K so whatever damage had been done was (I would like to think) from them, and wouldn't know about the original pads but probably. I'll have to make an appt.
2013 Explorer Sport
Quote from: liteyouup on January 28, 2015, 10:55:53 AM
Exactly, with the wife comment. Tendency is to ride them for some reason.
Some things we just do naturally, have to be conveyed to the wife; nicely, not condescending, probably more than a few times, and with some kind of bribe to help the understanding...lol
Rich
Time for an upgrade, will make a HUGE difference. Get the stoptech pads/rotors and remove the brake fade! :)
peppelepugh
EBC STAGE 4 SET ALL DAY! well, if they offer them for the explorer.
2011 Kona Blue SHO non-PP: MDesign Carbon Fiber CAI, All interior lights LEDs, LED Puddles, and LED Reverse.
EBC Stage 4 Brake kit, 170* T-stat, 3-Bar MAP, NGK Plugs, PPE Catless-DPs and Tune by Torrie!
BlackJac
I'd suggest to go with rotors that have a high carbon content and are Cryo-Treated. I went with Centric plain 125 Series Cryo-Treated rotors on my wife's 04' Acura TL with Brembo calipers and Hawk HPS pads.
2017 Fusion Sport - 401A/ Moonroof/ Magnetic Grey/ Livernois Motorsports 93 Stage 3
2015 Explorer Sport  - SOLD
Modded 1980 Corvette https://www.youtube.com/watch?v=4SUDndpy8bw
