13 SHO with PP, Corsa catback, and 2 bar unleashed 93octane Tune 346.27 WHP 385.95 WTQ
Started by Glassman710, January 22, 2015, 01:54:58 PM
wasinger3000
Quote from: ZSHO on January 22, 2015, 07:19:29 PM
Quote from: SHOnUup on January 22, 2015, 05:54:41 PM
Quote from: ZSHO on January 22, 2015, 04:20:38 PM
Quote from: wasinger3000 on January 22, 2015, 04:03:16 PM
I'm still trying to decide if I want to inject nitro with the meth. Or even a small amount of injector cleaner.
I was considering to also get a fire extiguisher,maybe i'll pick you up a couple.LOL.
Lol, kind and funny of you.
Rich
Thanks Rich,been trying to be a little proactive and not let the b.s bother me so much like the jeep guy,let Wassinger handle it for me,ha ha,LOL.
Haha.. I have a low tolerance.
13' GTCS, will be missed.
Rich
I was in the middle of reading that interesting little troll of frustration, but when I came back to read the juicy stuff it was gone...probably for the best. Guess some people just don't get the exclusivity the SHO has had since it's beginning. Keeping with that theme Ford may shock us all and retire the S-H-O for a few. It's been done before.
Rich
Courier6
That's very close to my numbers with comparable mods, I was lowered with downpipes;
http://youtu.be/svvG_njyM-A
2013 Tri-White PP, PPE downpipes, Corsa, Air Raid CAI, H&R Springs, 170 deg thermo, Livernois Dyno Tune 365 AWHP 407 AWTQ. Best 1/4 mile 12.580
Quote from: wasinger3000 on January 22, 2015, 07:26:01 PM
Rich
Thats really funny dude,never saw an ### like that!!!!!
f8tlSHO
Does the cat back really make that much of a difference? That's a good amount of power for a 2 bar.. How much boost are you running?
Sent from my iPhone
U can run 14-15 psi no problem on the stock map sensor...u could even run a little more...short term fuel trims would take care of it to a point...I think the stock tune would limit the max amount of fuel added by the O2 by 25 percent
Basically the computer won't know how much to fuel to add or why but based on the lambda readings from the 02 it will keep adding fuel to the max allowed until it gets back to desired lambda...if the Desired lambda at wot in the last load column is set to .80 then it will aim for that when the load reaches max as defined by the tables
f8tlSHO
So, a 3 bar running 15-16lbs of boost has what advantage?
Keeping o2's from overfueling?
Sent from my iPhone
Quote from: f8tlSHO on September 03, 2015, 12:54:38 PM
Sent from my iPhone
Eh it's not a bad question...personally I would get a 3 bar sensor if I was going to run 15 psi...but it's better to to operate in the middle of a sensors range than at the max..like gauges.. And it's would be less than ideal to rely on the o2's to add fuel...what if u have a bad 02?..that's also the reason the tune limits the allowable amount of fuel added or pulled by the o2's...u have to have limits in case of component failure or erroneous readings
f8tlSHO
Quote from: ajpturbo on September 03, 2015, 01:03:13 PM
Sent from my iPhone
That's a good point...
Sent from my iPhone
JDW1
13 SHO, Unleashed 3bar Tune, 1 step cooler NGK's, MDesign CAI, 170 t-stat and meth.
