Squeaking while turning the wheel to the left
Started by Scott13SHO, January 17, 2015, 05:11:04 PM
Scott13SHO
I've just noticed yesterday when I cut my wheel to the left and only to the left, I get a slight squeaking notice from the steering column area...should I be concerned (might be a ball joint?) or is it just from the temps ranging from freezing to friggen cold?
Ruby Red 2013 Ford Taurus SHO with Performance Package,Airaid CAI, MGP Red Caliper covers, LMS 93 Tune, Custom A-pillar Gauge pod with Aeroforce Interceptor Gauges, LED Interior and Exterior lights
CroR1
We'll need more info...does it come from the inside of the car or outside, suspension area? Record the sound if possible.
PokerMunkee
Maybe one of your caliper covers is coming off?
Might need to jack up front and have someone turn wheels while you get next wheels to see/hear what's going on.
2011 F-250 6.2 CCSB FX4
Scott to be honest with you could be so many variables causing this issue,first thing would start the car,and with the engine running turn the steering wheel all the way around and check to see if the left strut is dry or leaking,also could be weather related,have you had your car at the car wash recently?
Reproducible?  Maybe just needs a bit of extra foam in the column area.  Does the noise go away if you have the cover off at the time?
I recall a couple months ago after having the car reflashed at the dealer my steering column fell apart and was making a noise http://www.ecoboostperformanceforum.com/index.php?action=dlattach;topic=4079.0;attach=5707;image
My steering column started squeaking a couple months ago when started to get cold. But since then it went away. But had persisted I would have been investigating the steering angle sensor.
