Anyone ever tried Stright pipes on there SHO?
Started by MEANSHO, January 15, 2015, 12:42:30 PM
Jordan
Quote from: 18SHO on January 24, 2019, 01:20:38 PM
Quote from: Jordan on August 31, 2018, 06:00:48 PM
Quote from: 802SHO on August 31, 2018, 03:56:03 PM
Thank you guys for the input.  I will be going with an xpipe!
Thought I might add this. This is full 2.5" with an x pipe. So it's what you should expect it to look like in the end. This is with pie cuts though.
Love that setup, I'll be going with this x pipe! Did you mount the x pipe right where there he 3rd cat was or where the resonator was?
Also what mufflers are those ? MRT?
X pipe mounted basically where the third cat is and vibrant resonators
18SHO
Quote from: Jordan on January 24, 2019, 01:30:38 PM
Very nice, any sound clips of the car? Gotta sound real good
2018 SHO PP factory stock for now
AJPTURBO E30 tune stock plugs .028 gap
5.25.19 12.53 @ 112.96 1.85 60FT 1850 DA 71 F
Best trap 113.61
Jordan
18SHO
Quote from: Jordan on January 24, 2019, 02:19:27 PM
https://youtu.be/8Ecvw57OIx0 here is this set up in action
You think if I have stock downpipes but setup past that like your running it's loud enough without any drone?
Best trap 113.61
Jordan
With the catted downpipes it'll be a little bit more muffled. Honestly I think it would sound good. My biggest complaint about going to catless downpipes is it made it more prone to some rasp.
802SHO
Quote from: Jordan on January 24, 2019, 05:22:48 PM
For drone I don't even consider it a problem.  I've owned a car before with some serious drone...this is nothing.  And I get some rasp but honestly not a whole lot of that either.
https://youtu.be/IVDPcotk4dI
Jordan
Quote from: 802SHO on January 24, 2019, 05:28:15 PM
I drove 2 hours one way to the drag strip with open downpipes on the taurus. Never going to happen again. Learned my lesson
802SHO
Quote from: Jordan on January 24, 2019, 05:38:47 PM
I can only imagine how loud that was lol I'll take your word and not try that.
Jordan
Quote from: 802SHO on January 24, 2019, 06:43:20 PM
Well the first two hours was very loud and I stuffed napkins in my ears. The two hours back I contemplated totalling out the SHO as that seemed like a good plan of action at the time LOL
802SHO
Quote from: Jordan on January 24, 2019, 07:15:02 PM
Napkins in your ears!!  🤣  hahaha Holy $$$$!  That's loud!  I'm glad you didn't swerve off the road buddy
Jordan
What I get for trying to run a faster drag strip time LOL. Next time I will just pull it off at the strip bahaha
