Tablets for Data logging
Started by scott320, January 13, 2015, 04:20:28 PM
Quote from: ecoboostsho on November 16, 2015, 02:27:55 PM
Quote from: FoMoCoSHO on May 20, 2015, 11:58:10 PM
Galaxy Pro 8.4 running DashCommand which is lightening fast on this tablet
Can you enter custom PIDs in Dash Command by chance?
Yes but when you use the gauges instead of the standard dashboard, the performance slows to Torque levels.
f8tlSHO
Does anyone use a kindle fire? They are only 50$..
Sent from my iPhone
66 Galaxie
Quote from: f8tlSHO on November 16, 2015, 06:49:36 PM
Rear fuel pressure, boost, knock retard
Sent from my iPhone
Engine link does boost but does not do rear fuel pressure or show knock regard.  I will look into the actual PIDs and try building them as custom PIDs and report back.
ForscanLite does boost, fuel rail pressure and rear fuel pressure.  It lists knock timing but I need to take the car for a drive later to see if it actually reads it.  My suspicion is it does read it since it will show knock readings for all cylinders and does show normal spark advance
ecoboostsho
The knock PID works in Forscan on my car just fine. The individual cylinders do not.
Quote from: f8tlSHO on November 17, 2015, 12:19:58 PM
Sent from my iPhone
Last time I checked only amazon approved apps are allowed and none of the diagnostic stuff was listed. Unless that has changed, you would have to side load the app.
MKSecobeast
I have and they have a program similar to torque. I forget what it's called, but search for torque and the one i'm talking about pops up. It has everything that torque has I do believe..
10' MKS Ecoboost, Thunderstorm CAI, Evenflo T-stat, Livernois 0.30 plugs, 3 bar map, my cal tuner, LMS non-catted dp's, LMS 93 stage 4 plus tune, 7' tablet running torque pro, factory 20's,custom badges and decals.
