Tablets for Data logging
Started by scott320, January 13, 2015, 04:20:28 PM
scott320
 So I want to mount a tablet in my SHO for torque pro data logging .  I found a cheap Netbook tablet at walmart. It has the google play store, so getting the torque pro app should be easy.  Just wondering if the tablet choice is important to set this up i my car?  Any help will be great.
http://www.walmart.com/ip/Nextbook-7-Tablet-16GB-Quad-Core/38334381
I have a pretty basic tablet, Samsung Tab2. Does great, little rough to read on certain light angles. Not to bad having tint all the way around. If I was to upgrade it'd be one with glare blocker. But see no need to.
Rich
Seems to have decent specs with the latest wifi & bluetooth & OS version.  Should work.
Nextbook NX700QC16G with WiFi 7" Touchscreen Tablet PC:
Technical Specifications:
    Android 4.4 (Kit Kat) OS
    1.6GHz MediaTek MT8127 ARM Cortex-A7 Quad-Core processor
    Nextbook 7" Tablet has 1GB DDR3 of system memory
    7.0" touchscreen, 1024 x 600 resolution
    option to expand via microSD slot to 64GB more
    16GB quad-core tablet has a built-in 802.11b/g/n WiFi and Bluetooth v4.0
jtoddk98
Quote from: scott320 on January 13, 2015, 04:20:28 PM
I bought a Moto G on eBay for $38, mounted it to a Garmin suction cup and put it on the top of my windshield on top of the rear view mirror. I got a 12ft USB cable on Amazon for $6 and wired it through the headliner, down the driver side a pillar, down the dash, and into the console where I have a little 2port usb charger that plugs into the 12v outlet, The phone draws so little power so I'm not worried about it draining the battery.
2011 Taurus SHO Performance Package. EBC Stage 4 Brakes. Blacked out chrome. #130 of 602 in Ingot Silver
Gray Brick
2013 Ecoboost Ford Flex
jtoddk98
Here's one from when I had an older android phone. I was able to put the Moto g higher up so it doesn't block the rear view mirror because the charge port is on the bottom, not on the side like this old phone. Have my 9500ix handing from the rear view mirror post
BigB15
I have a HP Stream 7" , on suction mount .
Running Dash Commander
and a BT OBD device
15/PP SHO UnLeashed
12.96@106.6
Galaxy Pro 8.4 running DashCommand which is lightening fast on this tablet
f8tlSHO
Quote from: FoMoCoSHO on May 20, 2015, 11:58:10 PM
Is dash command a good program to use? I can get that on my iPhone. Or my buddy was gonna sell me a galaxy tablet. I also found this one that looks like it supports torque pid files.. It's called engine link
Sent from my iPhone
ecoboostsho
Can you enter custom PIDs in Dash Command by chance?
66 Galaxie
Quote from: f8tlSHO on November 16, 2015, 12:56:14 PM
Sent from my iPhone
I also have an iPhone and have done some playing with both EngineLink and Forscan lite.
Engine link does allow for custom pids but they don't always work.  In particular I haven't gotten tire pressures to work or fuel rail pressure.
Forscan Lite doesn't allow custom PIDs but has a more extensive list of pids loaded and does show me data for tire pressures and fuel rail.
What PIDs are you looking to access?
f8tlSHO
Rear fuel pressure, boost, knock retard
Sent from my iPhone
66 Galaxie
I'll try to take a look tomorrow and check for you.
f8tlSHO
Quote from: 66 Galaxie on November 16, 2015, 08:21:43 PM
ok
Thanks
Sent from my iPhone
