- Forum Supporters
- Elite Member
- Logged
Why might ethanol help reduce that visible soot on exhaust tips?
QuoteSize distribution, chemical composition and oxidation reactivity of particulate matter from gasoline direct injection (GDI) engine fueled with ethanol-gasoline fuel
Yueqi Luo, Lei Zhu, Junhua Fang, Zhuyue Zhuang, Chun Guan, Chen Xia, Xiaomin Xie, Zhen Huang
Highlights
• Ethanol-gasoline reduces elemental carbon in PM.
• Ethanol-gasoline increases volatile organic fraction in PM.
• Soot generated from ethanol-gasoline has higher oxidation activity.
Abstract
Ethanol-gasoline blended fuels have been widely applied in markets recently, as ethanol reduces life-cycle greenhouse gas emissions and improves anti-knock performance. However, its effects on particulate matter (PM) emissions from gasoline direct injection (GDI) engine still need further investigation. In this study, the effects of ethanol-gasoline blended fuels on particle size distributions, number concentrations, chemical composition and soot oxidation activity of GDI engine were investigated. It was found that ethanol-gasoline blended fuels increased the particle number concentration in low-load operating conditions. In higher load conditions, the ethanol-gasoline was effective for reducing the particle number concentration, indicating that the chemical benefits of ethanol become dominant, which could reduce soot precursors such as large n-alkanes and aromatics in gasoline. The volatile organic mass fraction in ethanol-gasoline particulates matter was higher than that in gasoline particulate matter because ethanol reduced the amount of soot precursors during combustion and thereby reduced the elemental carbon proportions in PM. Ethanol addition also increased the proportion of small particles, which confirmed the effects of ethanol on organic composition. Ethanol-gasoline reduced the concentrations of most PAH species, except those with small aromatic rings, e.g., naphthalene. Soot from ethanol-gasoline has lower activation energy of oxidation than that from gasoline. The results in this study indicate that ethanol-gasoline has positive effects on PM emissions control, as the soot oxidation activity is improved and the particle number concentrations are reduced at moderate and high engine loads.
Keywords
Gasoline direct injection (GDI) engine; Particulate matter (PM); Ethanol-gasoline; Organic compositions; Soot oxidation activity
Corresponding authors. Tel./fax: +86 21 34205949.
Copyright © 2015 Elsevier Ltd. All rights reserved.
