Winter / cold ambient air how it affects your vehicle.
Started by tmcphail, November 20, 2014, 01:04:17 PM
tmcphail
Take care,
Mr. Torrie R. McPhail - Owner
Unleashed Tuning Ford/GM/DCX SCT Custom Calibrator
EcuTek Nissan R35 GTR Custom Tuner
HPTuners Custom Tuner / Dealer
MDesign Performance
If there's a way to get into the pump internals than we could possibly create something similar to the item below.
http://www.ctsturbo.com/cart/products/Autotech_FSI_High_Pressure_Fuel_Pump_Upgrade_Kit-463-0.html
I think that is our best bet, unless we somehow find a Bosch pump that is similar to ours yet outputs more PSI.
sales@mdesignperformance.com
www.mdesignperformance.com
tmcphail
I believe that core problem has been the inability to take the stock pump apart and upgrade it. I am by no means a fuel pump engineer. I just know we need more GPH
Take care,
What about anything external belt driven secondary fuel pump like the common rail diesel pickups use.  Hell if we could use there pump we would have more than enough pressure. Since them run at 20-29,000 psi
tmcphail
I don't know how easy or feasible that would be to implement.
Take care,
It wouldnt be as easy on the transverse mounted motors, but would be possible for the pickups and mustang with more engine bay space.. The kits wouldnt be cheap though.. As you would have to get a new fuel rail, custom wire harness to split the signal to fuel pumps and possible a better in tank set up which has already been discussed.
tmcphail
Take care,
I rebuilt the cam driven, HPFP on my Speed6 myself. Just a set of upgraded internals. Easy peasy. I'm no expert either, but it still seems possible with our pumps.
But that will only get one so far. It'll give some cushion at least, and widen the window for E blend tuning possibly.
Anybody really getting into big power would benefit most greatly from an auxiliary port injector.
