Blowing off cap on throttle body servo drive?
Started by 91hybrid, November 07, 2014, 06:25:25 PM
Dang. Guess I better go check under my hood. Haven't poked around under there in a while!
wasinger3000
I think it could be from shutting the throttle plate under high boost. The pressure build up cannot be related quick enough so some escapes though the servo. I'm not sure anything but a very serious adhesive will keep it in place. Then you will never have access to this point. I think it's best to leave it off.
I do not wash my engine bay so I am not worried about water.
13' GTCS, will be missed.
That cap sure does not look like a reliable source of a air pressure seal,that cap should be addressed and updated,looks more like a cap from a can of WD-40.
boostedbull
The seal should be in the servo. But if boost blew the cap off then boost got past the seal.
2012 SHO PP - Tuned by Torrie
12.8 @ 106  tune only
Yes, it looks like a dust cap. Not for serving as a seal.
91hybrid
I agree the the cap is not substantial, but there is an o-ring that seals the cap to the housing. This may be more for keeping water out than keeping boost in.
2014 SHO -PP, Unleashed Tuned, 3bar, Devils Own 100% meth, PPE catted down pipes, 3rd cat delete, Magnaflow 2.5" exhaust, 170 deg, NGK 7's plugs, hot pipes - White Platinum 401a
418 whp - 513 wlb/ft
non meth 13.11@103.6 (knock limited)
Meth pass 11.991@114.28
Looks like we need a volunteer to ride under the hood for some first hand testing....lol :P
Rich
Finally, a way to put those pesky kids to good use :D
 :)Checked mine also,seems to be intact. :)
