"Complete" List of TSB's for your 2013+ SHO
Started by SHOdded, October 16, 2014, 07:05:45 PM
2007-2016 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police – AWD – Ticking/Knocking Noise From Driveline – Built On Or Before 30-Jun-2016
http://www.ecoboostperformanceforum.com/index.php/topic,496.msg114980.html#msg114980
SB-10053412-4688
Manufacturer Communication Number: ASI-32238
Summary
FORD/LINCOLN: SOME VEHICLES MAY EXPERIENCE, A SLIPPAGE DURING SHIFTING OR POSSIBLE CLUTCH DAMAGE MIGHT HAVE HYDRAULIC FLUID LEAK IN VALVE BODY. MODELS 2013 EDGE, MKX, FLEX, TAURUS, MKT, MKS, MKZ.
SHOurpp
just had the p2112 tb stuck closed fail on a 2016 8500 miles
duel 3 inch cat less down pipes
sct x4- as a scanner/logger only
3 bar map
hp tuners
both bovs vta
Quote from: SHOurpp on April 27, 2017, 09:00:00 AM
Now happening on the SHO?  Jeez!
SHOurpp
everyone said they never seen it on a sho but actuator stuck closed and a trip to the dealer
interesting note
the original one you could see the gold galvanized blade nut on the side. i tried to use a crescent wrench to free it when i was stuck along the road
the replacement is a sealed unit-
3 bar map
hp tuners
both bovs vta
The TB motor has been known to die on occasion.  That plate is like a snapping turtle, care must be exercised if the TB is electrically connected.
Quote from: AJP turbo on April 27, 2017, 06:21:19 PM
That code also comes up as faulty wiring or a shorted throttle body wiring harness and even a bad pcm.
I remember you having problems with flashing the car and the ecu locking up.
Seems wierd that the throttle body blade seized up after all this time...you can usually push the throttle blade open with your finger...its just a plate on a shaft in a hole
What R U talking about ? that throttle blade will sever your finger right off if not disconnected properly and would advise caution.
It could also be a faulty electrical connector. Z
Quote from: AJP turbo on April 27, 2017, 09:25:37 PM
Quote from: ZSHO on April 27, 2017, 08:52:22 PM
Sometimes i wonder what planet you are from...it wont sever your finger
Im just  saying if you took off the pipe and looked at the closed throttle blade you can easily push it with your finger if you were seeing if it was stuck
Zsho, are you the type of person that thinks it's appropriate that the car mfg's are required to tell people that the commercials are filmed on a closed course and should not be attempted?
You are not suppose to intervene with natural selection...if someone is dumb enough to do something that harms them then it was suppose to happen...you may be keeping people alive that shouldnt be
what's wrong with advising caution!!!! It will sever your finger off if precautionary measures are not taken that's all.
I think you need to move on my friend. Z
A lot of people never get into the knitty gritty of the mechanicals of their cars.  Many are simply not uptodate on the technology.  Doesn't make them dumb or foolhardy.
SHOurpp
starting to wonder if wmi took it out?
although it would ingest all the water at 20 psi
3 bar map
hp tuners
both bovs vta
SHOurpp
thanks no worries
as posted above i tried to use a wrench on the outside of the tb to free up the blade - didn't move
the warranty one does not allow access that way its sealed off
3 bar map
hp tuners
both bovs vta
2017 Explorer/Taurus/Police – 3.5L or 3.7L TiVCT Engine – Illuminated MIL – DTC P0740 or P0743 – Built On 14-Jun-2017 And Through 21-Jun-2017
Some 2017 Explorer/Taurus/Police vehicles equipped with a 3.5L or 3.7L twin independent variable camshaft timing (TiVCT) engine, built on 14-Jun-2017 and through 21-Jun-2017, may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0740 or P0743 stored in powertrain control module (PCM) memory.
Prior to replacing any components, check pin 14 in connecter c168 for correct fitment, tension, push out, or any signs of damage.
If terminal replacement is necessary, pigtail kit 8U2Z-14S411-ACB can be ordered to obtain the terminal with wire lead.
If no concerns are found with C168, follow normal diagnostic routines for the fault codes.
2017 Explorer/Taurus/Police Interceptor – Fixed Brake Pedal – Brake Drag – Built On 19-May-2017 And Through 30-May-2017
Some 2017 Explorer, Taurus, Police Interceptor vehicles built on 19-May-2017 and through 30-May-2017 equipped with a fixed brake pedal assembly may exhibit a brake drag concern or residual pressure in the brake system with the brake pedal fully released.
This may be due to an interference condition between the brake pedal arm stop lamp switch bracket and the booster push rod clevis pin bracket.
Inspect for a touch condition between the brake pedal arm stop lamp switch bracket and the brake booster push rod clevis pin bracket.
If a touch condition exists, replace the brake pedal assembly.
Safety Recall 17S23 – Electronic Power Assist Steering Heat Shield Fastener Inspection – 2017 Ford Explorer & Taurus
August 28, 2017 NHTSA Campaign Number: 17V530000
Loss of Power Assisted Steering
If the heat shield detaches, the steering gear may overheat, increasing the steering effort required by the driver, especially at lower speeds, and increasing the risk of a crash.
Manufacturer Ford Motor Company
Components STEERING
Potential Number of Units Affected 253
Summary
In some of the affected vehicles, the fasteners used to secure the electronic power assist steering (EPAS) heat shield may not have sufficient corrosion protection.  If the fasteners do not have sufficient corrosion protection, they may not retain the heat shield over time, exposing the steering gear to higher than expected temperatures.  If the steering gear connectors melt, the driver may experience loss of assist accompanied by the fault message "SERVICE POWER STEERING NOW" in the instrument cluster.  Loss of power steering assist while driving would result in higher steering efforts, especially at lower speeds.
Remedy
Ford will notify owners, and dealers to inspect and replace the heat shield fasteners as needed, free of charge. The recall began on September 13, 2017. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 17S23.
Notes
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
4 Affected Products
Vehicles
MAKE   MODEL   YEAR
FORD    EXPLORER    2017
FORD    POLICE INTERCEPTOR SEDAN    2017
FORD    POLICE INTERCEPTOR UTILIT    2017
FORD    TAURUS    2017
