"Complete" List of TSB's for your 2013+ SHO
Started by SHOdded, October 16, 2014, 07:05:45 PM
TSB 14-0060 (supersedes TSB 14-0042)
POLICE INTERCEPTOR – ERRATIC OPERATION OF CLIMATE CONTROL BLOWER MOTOR – LOSS OF COMMUNICATION WITH HVAC MODULE
Publication Date: March 21, 2014
FORD: 2013-2014 Explorer, Taurus
The article supersedes TSB 14-0042 to update the Service Procedure.
ISSUE:
Some 2013-2014 Taurus and Explorer Police Interceptor vehicles may exhibit a concern of erratic operation of the climate control blower motor and the inability to communicate with the heating ventilation air conditioning (HVAC) module over the network during repair diagnosis.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Explorer
1.Remove the left front seat. Refer to Workshop Manual (WSM), Section 501-10.
2.Remove the B-pillar trim panel. Refer to WSM, Section 501-05.
3.Pull back enough of the floor covering material to expose electrical connector C3403 containing a jumper plug/cap. Refer to Wiring Diagram, Section 152-1.
4.Cut the individual circuits close to the connector leaving as much of the original circuit length as possible. Remove C3403 from the vehicle wiring harness.
5.Using the solder splicing method join the same colored circuits together, eliminating the connector and jumper plug/cap. Use heat shrink tubing to complete the repair. Refer to Wiring Diagram, Section 5-1.
6.Reverse the procedure to reassemble the vehicle.
Taurus
1.Remove the left front seat. Refer to WSM, Section 501-10.
2.Remove the front scuff plate trim panel. Refer to WSM, Section 501-05.
3.Pull back enough of the floor covering material to expose electrical connector C3379 containing a jumper plug/cap. Refer to Wiring Diagram, Section 152-1.
4.Cut the individual circuits close to the connector leaving as much of the original circuit length as possible. Remove C3379 from the vehicle wiring harness.
5.Using the solder splicing method join the same colored circuits together eliminating the connector and jumper plug/cap. Use heat shrink tubing to complete the repair. Refer to Wiring Diagram, Section 5-1.
OPERATION    DESCRIPTION    TIME
140060A 2013-2014 Taurus Police: Bypass Electrical Connector Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.5 Hrs.
140060A 2013-2014 Explorer Police: Bypass Electrical Connector Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.8 Hrs.
MT140060 Additional Time To Remove Any Police Equipment That Would Interfere With Connector Access Can Be Claimed With Operation A Actual Time
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO.    CONDITION CODE
14A005                  28
TSB 14-0091
3.5L GTDI ENGINE – RAW FUEL-TYPE ODOR NEAR INTAKE MANIFOLD – BUILT ON OR BEFORE 2/20/2014
Publication Date: April 30, 2014
FORD: 2014 Explorer, Flex, Taurus
LINCOLN: 2014 MKS, MKT
ISSUE:
Some 2014 Explorer, Flex, MKT, MKS, and Taurus vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 2/20/2014 may exhibit a raw fuel-type odor that is most noticeable near the intake manifold.
ACTION:
SERVICE PROCEDURE
1.Remove the intake manifold. Refer to Workshop Manual (WSM), Section 303-01.
2.Replace the high-pressure fuel tube. Refer to WSM, Section 303-04. a.It is not necessary to remove the fuel injection pump to perform this procedure.
3.Install the intake manifold. Refer to WSM, Section 303-01.
PART NUMBER      PART NAME
AA5Z-9J323-E   High-Pressure Fuel Tube Assembly
AA5Z-9439-A    Intake Gasket Set (Includes 6)
7T4Z-9439-D    Gasket – Intake Manifold
AA5Z-9439-BA   Gasket – Intake Manifold
VC-3-B         Motorcraft® Orange Antifreeze/Coolant Concentrated
140091A 2014 MKS And Taurus 3.5L GTDI: Replace The High-Pressure Fuel Tube (Do Not Use With Any Other Labor Operations) 2.5 Hrs.
140091A 2014 Explorer 3.5L GTDI: Replace The High-Pressure Fuel Tube (Do Not Use With Any Other Labor Operations) 2.6 Hrs.
140091A 2014 Flex And MKT 3.5L GTDI: Replace The High-Pressure Fuel Tube (Do Not Use With Any Other Labor Operations) 2.7 Hrs.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.
DEALER CODING
9J323                   D8
TSB 14-0102
ILLUMINATED MIL WITH DTC P0420 AND/OR P0430 – BUILT ON OR BEFORE 4/25/2014
Publication Date: May 9, 2014
LINCOLN: 2013-2014 MKS, MKT
ISSUE:
Some 2013-2014 Police Explorer, Police Taurus, MKT Livery and MKS vehicles equipped with a 3.5L or 3.7L engine and built on or before 4/25/2014 may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P0420 and/or P0430.
ACTION:
SERVICE PROCEDURE
1.Connect the Ford Integrated Diagnostic System (IDS) service tool or equivalent and check for DTCs. Is DTC P0420 and/or P0430 present?
  a.No – this article does not apply. Refer to Powertrain Control/Emission Diagnosis (PC/ED) manual for normal diagnosis.
  b.Yes – replace the affected catalytic converter per the DTC. Refer to Workshop Manual (WSM), Section 309-00. Proceed to Step 2.
2.Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 90.02 and higher. Calibration files may also be obtained at www.motorcraftservice.com.
DA8Z-5G232-C   Front Catalyst Converter Assy
DA8Z-5G232-D   Rear Catalyst Converter Assy
W716011-S430   Manifold-To-Cylinder Head Stud Nut (12 Req)
W712244-S300   Manifold-To-Cylinder Head Stud (12 Req)
W520414-S441   Y-Pipe Nut (8 Req)
DG1Z-9448-A    Manifold Gasket (2 Req)
140102A 2013-2014 Police Taurus FWD 3.5L/3.7L: Check DTCs, Replace The Right Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.6 Hrs.
140102A 2013-2014 Police Taurus AWD 3.5L/3.7L: Check DTCs, Replace The Right Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.8 Hrs.
140102A 2013-2014 MKS/MKT Livery FWD 3.7L: Check DTCs, Replace The Right Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.7 Hrs.
140102A 2013-2014 MKS/MKT Livery AWD 3.7L: Check DTCs, Replace The Right Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.9 Hrs.
140102A 2013-2014 Police Explorer FWD 3.5L/3.7L: Check DTCs, Replace The Right Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 2.0 Hrs.
140102A 2013-2014 Police Explorer AWD 3.5L: Check DTCs, Replace The Right Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 2.2 Hrs.
140102A 2013-2014 Police Explorer AWD 3.7L: Check DTCs, Replace The Right Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 2.3 Hrs.
140102B 2013-2014 Police Taurus FWD 3.5L/3.7L: Check DTCs, Replace The Left Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.6 Hrs.
140102B 2013-2014 Police Taurus AWD 3.5L/3.7L: Check DTCs, Replace The Left Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.6 Hrs.
140102B 2013-2014 MKS/MKT Livery FWD 3.7L: Check DTCs, Replace The Left Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.6 Hrs.
140102B 2013-2014 MKS/MKT Livery AWD 3.7L: Check DTCs, Replace The Left Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.6 Hrs.
140102B 2013-2014 Police Explorer FWD 3.5L/3.7L: Check DTCs, Replace The Left Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.6 Hrs.
140102B 2013-2014 Police Explorer AWD 3.5L: Check DTCs, Replace The Left Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.7 Hrs.
140102B 2013-2014 Police Explorer AWD 3.7L: Check DTCs, Replace The Left Hand Catalytic Converter And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 1.7 Hrs.
140102C 2013-2014 Police Taurus FWD 3.5L/3.7L: Check DTCs, Replace Both Right And Left Hand Catalytic Converters And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 2.7 Hrs.
140102C 2013-2014 Police Taurus AWD 3.5L/3.7L L: Check DTCs, Replace Both Right And Left Hand Catalytic Converters And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 2.9 Hrs.
140102C 2013-2014 MKS/MKT Livery FWD 3.7L: Check DTCs, Replace Both Right And Left Hand Catalytic Converters And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 2.5 Hrs.
140102C 2013-2014 MKS/MKT Livery AWD 3.7L: Check DTCs, Replace Both Right And Left Hand Catalytic Converters And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 2.8 Hrs.
140102C 2013-2014 Police Explorer FWD 3.5L/3.7L: Check DTCs, Replace Both Right And Left Hand Catalytic Converters And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 2.9 Hrs.
140102C 2013-2014 Police Explorer AWD 3.5L: Check DTCs, Replace Both Right And Left Hand Catalytic Converters And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.1 Hrs.
140102C 2013-2014 Police Explorer AWD 3.7L: Check DTCs, Replace Both Right And Left Hand Catalytic Converters And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.2 Hrs.
WARRANTY STATUS
DEALER CODING
5G232                     04
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
•Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
•Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
TSB 14-0105
3.5L GTDI DIAGNOSTIC TROUBLE CODE (DTC) P0087 – BUILT ON OR BEFORE 6/1/2014
Publication Date: May 19, 2014
FORD: 2012-2014 Flex, Taurus; 2013-2014 Explorer
LINCOLN: 2012-2014 MKT
ISSUE:
Some 2013-2014 Explorer, 2012–2014 Taurus, MKT and Flex vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 6/1/2014 may exhibit a rough idle and/or DTC P0087 after a hot engine restart.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 90.03 and higher. Calibration files may also be obtained at www.motorcraftservice.com.
NOTE: ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE'S COMPUTER TO LEARN THE TRANSMISSION'S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS.
140105A 2013-2014 Explorer, 2012-2014 Taurus, MKT, Flex 3.5L GTDI: Retrieve DTCs, Reprogram The PCM Includes Time To Clear Codes (Do Not Use With Any Other Labor Operations) 0.3 Hr.
WARRANTY STATUS
DEALER CODING
RECALEM                 04
TSB 14-0109
RIGHT HAND MULTIMEDIA DISPLAY AREA MISSING THE COMPASS AND TURN BY TURN DISPLAY – BUILT ON OR BEFORE 1/25/2014
Publication Date: May 22, 2014
FORD: 2014 Taurus
LINCOLN: 2014 MKS
ISSUE:
Some 2014 Taurus or MKS vehicles built on or before 1/25/2014 may exhibit an issue where the instrument panel cluster (IPC) right hand multimedia display area is missing the compass and turn-by-turn display.
ACTION:
SERVICE PROCEDURE
1.Using Integrated Diagnostic System (IDS), Select ToolBox, Module Programming, As-built, IPC.
2.Use the automatic function for programming the module with the as-built data pulled from PTS.
140109A 2014 Taurus, MKS: Program The IPC Module Using As-Built Data (Do Not Use With Any Other Labor Operations) 0.2 Hr.
WARRANTY STATUS
DEALER CODING
10849                   04
TSB 14-0123 (supersedes TSB 14-0027)
HD RADIO INOPERATIVE – DIAGNOSTIC TROUBLE CODE (DTC) U3000:96
Publication Date: June 30, 2014
FORD: 2013-2014 Escape, Flex, Fusion, Taurus
LINCOLN: 2013-2014 MKS, MKT, MKZ
This article supersedes TSB 14-0027 to remove the production fix date, update the vehicle model lines and Action Statement.
ISSUE:
Some 2013-2014 Escape, Fusion, MKZ, Taurus, Flex, MKS and MKT vehicles may exhibit an HD radio inoperative with DTC U3000:96 stored in the audio control module (ACM).
ACTION:
Reprogram the ACM to the latest calibration using IDS release 90.05 and higher. Calibration files may also be obtained at www.motorcraftservice.com.
140123A Check DTCs, Reprogram The ACM And Clear DTCs (Do Not Use With Any Other Labor Operations) 0.3 Hr.
WARRANTY STATUS
DEALER CODING
18C869                   42
TSB 14-0130 (supersedes TSB 12-12-4)
EXHAUST ODOR IN VEHICLE
Publication Date: July 22, 2014
FORD: 2011-2015 Explorer
This article supersedes TSB 12-12-4 to update the vehicle model years and Service Procedure.
ISSUE:
Some 2011-2015 Explorer vehicles may exhibit an exhaust odor in the vehicle with the auxiliary climate control system on. Customers may indicate the odor smells like sulfur.
ACTION:
SERVICE PROCEDURE
1.Reprogram the Heating Ventilation Air Conditioning (HVAC) module to the latest calibration using IDS release 91.02 or higher. Calibration files may also be obtained at www.motorcraftservice.com. a.When reprogramming the HVAC, IDS will have additional questions that require a yes response to reprogram the module.
2.Remove the rear bumper cover. Refer to Workshop Manual (WSM), Section 501-19.
3.Replace the left side rear air extractor. (Figure 1)
Figure 1 – 14-0130
4.Install the rear bumper cover. Refer to WSM, Section 501-19. a.Apply masking tape around the outer edge of the rear fender mouldings to protect the vehicle from damage.
5.Open the liftgate and inspect for the presence of drain valves in the two (2) drain holes on the left and right side of the liftgate. Are the drain valves present? (Figure 2)
  a.Yes – no further action is required. Repair is complete.
  b.No – proceed to Step 6.
6.Install a new drain valve in each of the two (2) drain holes on the left and right side of the liftgate. (Figure 2)
Figure 2 – 14-0130
7.Raise the vehicle on hoist. Refer to WSM, Section 100-02.
8.Lower and support the rear section of the exhaust system.
9.Clean the areas on the underside of the vehicle where the seam sealer will be applied. (Figures 3-5)
Figure 3 – 14-0130
Figure 4 – 14-0130
Figure 5 – 14-0130
10.Cover the exhaust system and auxiliary climate control drain.
11.Apply a generous amount of Motorcraft® Seam Sealer to rear horizontal sheet metal lap joints on left and right sides of the vehicle, and the rear sheet metal overlap flange across the rear of the vehicle. (Figures 3-5)
12.Spray a generous amount of 3M™ Rubberized Undercoating around the auxiliary air conditioning lines and seam sealer areas. (Figure 6)
Figure 6 – 14-0130
13.Install the rear exhaust system.
Obtain Parts Locally
Part Number Part Description
08882         3M™ Rubberized Undercoating
BB5Z-61280B62-B  Dual Rate Air Extractor
BB5Z-7829164-AA  Wheel Lip Moulding Right Hand
BB5Z-7829165-AA  Wheel lip Moulding Left Hand
4M8Z-54280B62-A  Valve Assembly Auto Drain
TA-2 Motorcraft® Seam Sealer
140130A 2011-2015 Explorer: Reprogram The HVAC Module, Replace Air Extractors And Both Rear Fender Mouldings (Do Not Use With Any Other Labor Operations) 1.3 Hrs.
140130B 2011-2015 Explorer: Reprogram The HVAC Module, Replace Air Extractors Both Rear Fender Mouldings, Seal The Body And Install Liftgate Drain Valves (Do Not Use With Any Other Labor Operations) 2.0 Hrs.
WARRANTY STATUS
DEALER CODING
61280B62               07
TSB 14-0132
EASY FUEL CAPLESS – CONCERNS WITH FUEL NOZZLE INSERTION OR REMOVAL
FORD: 2009-2014 Escape, Expedition, F-150, Flex; 2010-2014 Fusion, Mustang, Transit Connect; 2011-2014 Edge, Fiesta; 2012-2014 Focus; 2013-2014 C-MAX; 2008-2015 Explorer; 2010-2015 Taurus; 2015 Transit
LINCOLN: 2009-2014 MKS, Navigator; 2010-2014 MKT, MKZ; 2011-2014 MKX
MERCURY: 2008-2010 Mountaineer; 2009-2011 Mariner; 2010-2011 Milan
ISSUE:
Some vehicles equipped with the Easy Fuel™ Capless Fuel System may exhibit a concern where a fuel nozzle cannot be inserted and/or removed. This concern may be caused by a problem with the fuel station nozzle. The sleeve at the tip of the spout may be missing, not allowing the nozzle to be inserted, or could be loose/gapped not allowing the nozzle to be removed once inserted.
ACTION:
Follow the service procedure steps to correct the condition.
SERVICE PROCEDURE
1.Provide the customer with the customer information sheet. (Figure 2)
2.Identify the customer concern.
  a.For fuel nozzle insertion concerns, proceed to Step 3.
  b.For fuel nozzle removal concerns, proceed to Step 5.
3.Verify normal system operation by attempting to insert the Easy Fuel™ funnel supplied with the vehicle into the fuel tank filler pipe. a.The funnel is typically located near the spare tire or jacking tools. Refer to the Owner's Guide for funnel location as required.
4.Does the Easy Fuel funnel insert normally?
  a.Yes – the system is operating normally. This article does not apply.
  b.No – replace the fuel tank filler pipe. Refer to Workshop Manual (WSM), Section 310-01. Repair is complete.
5.Is the fuel station nozzle still stuck in the fuel tank filler pipe?
  a.Yes – Remove the single hex head set screw at the base of spout near the handle cover. Twist and pull the nozzle handle to separate from the spout. Once the fuel nozzle handle is separated from the spout, the fuel tank filler pipe can be replaced. Refer to WSM, Section 310-01. (Figure 1)
  Figure 1 – 14-0132
  b.No – inspect the fuel tank filler pipe for physical damage or for the nozzle sleeve remaining inside the capless device.
6.Is the nozzle sleeve visible in the fuel tank filler pipe, or is the fuel filler pipe damaged?
  a.Yes – replace the fuel tank filler pipe. Refer to WSM, Section 310-01. Repair is complete.
  b.No – the system is operating normally. No further service is required.
9032                      Fuel Filler Neck — See Parts Catalog For Complete Listing (All Focus/ 2013 And Newer Escape Only)
9034                      Fuel Filler Neck — See Parts Catalog For Complete Listing (All Vehicles Except Focus/ 2013 And Newer Escape)
140132A 2013-2014 Fusion, MKZ, 2011-2014 Fiesta, Edge, MKX: Replace The Fuel Filler Pipe Includes Time To Test Nozzle Insertion Or Remove Fuel Station Nozzle (Do Not Use With Any Other Labor Operations) 0.8 Hr.
140132A 2011-2015 Explorer, 2010 Mustang 4.0L SOHC: Replace The Fuel Filler Pipe Includes Time To Test Nozzle Insertion Or Remove Fuel Station Nozzle (Do Not Use With Any Other Labor Operations) 0.9 Hr.
140132A 2010-2015 Taurus, 2010-2014 Flex, MKT, MKS, 2009-2014 F-150, 2015 Transit, 2009-2014 Expedition, Navigator, 2009-2014 Escape, 2009-2011 Mariner: Replace The Fuel Filler Pipe Includes Time To Test Nozzle Insertion Or Remove Fuel Station Nozzle (Do Not Use With Any Other Labor Operations) 1.0 Hr.
140132A 2010-2014 Mustang, Transit Connect: Replace The Fuel Filler Pipe Includes Time To Test Nozzle Insertion Or Remove Fuel Station Nozzle (Do Not Use With Any Other Labor Operations) 1.1 Hrs.
140132A 2010-2012 Fusion FWD, MKZ FWD, 2010-2011 Milan, 2013-2014 C-MAX: Replace The Fuel Filler Pipe Includes Time To Test Nozzle Insertion Or Remove Fuel Station Nozzle (Do Not Use With Any Other Labor Operations) 1.2 Hrs.
140132A 2008-2010 Explorer, Mountaineer: Replace The Fuel Filler Pipe Includes Time To Test Nozzle Insertion Or Remove Fuel Station Nozzle (Do Not Use With Any Other Labor Operations) 1.6 Hrs.
140132A 2010-2012 Fusion AWD, MKZ AWD, 2010-2011 Milan AWD: Replace The Fuel Filler Pipe Includes Time To Test Nozzle Insertion Or Remove Fuel Station Nozzle (Do Not Use With Any Other Labor Operations) 1.8 Hrs.
WARRANTY STATUS
This is not a repair covered by warranty, but is otherwise eligible Under Special Programs Provisions Requiring Special Claims Coding as listed below: This special program expires on 12/31/2015. No repairs performed after 12/31/2015 are covered.
SPECIAL DEALER CLAIM CODING:
Program Code: R02
9032 (all Focus, 2013 and newer Escape only) or 9034 (all others) 02
Figure 2 – 14-0132
TSB 15-0056 (supersedes TSB 14-0032)
AWD – LEAK FROM PTU – BUILT ON OR BEFORE 12/11/2013
Publication Date: April 17, 2015
This article supersedes TSB 14-0032 to update the Service Labor Time Standards.
ISSUE:
Some 2013-2014 Explorer, Taurus and MKS vehicles equipped with all wheel drive (AWD) and built on or before 12/11/2013 may exhibit power transfer unit (PTU) fluid leaking. This concern may be due to a PTU vent hose which is missing or disconnected.
ACTION:
SERVICE PROCEDURE
1.Raise the vehicle on a hoist. Refer to Workshop Manual (WSM), Section 100-02.
2.Is the PTU equipped with a jiggle cap style vent assembly?
   a.Yes – this article does not apply. Refer to WSM, Section 308-07 for normal diagnostics.
   b.No – proceed to step 3.
3.Is the PTU vent hose missing or disconnected?
  a.Yes – install a new hose.
     i.Twin Independent Variable Cam Timing (Ti-VCT) engine. (Figure 1)
     Figure 1 – 15-0056
     ii.Gasoline Turbocharged Direct Injection (GTDI) engines. (Figure 2)
     Figure 2 – 15-0056
  b.No – this article does not apply. Refer to WSM, Section 308-07 for normal diagnostics.
4.Clean fluid residue from the vehicle by applying Motorcraft® Metal Brake Parts Cleaner or equivalent on a rag and wiping the area clean. a.Use caution not to introduce brake cleaner into the PTU fluid.
5.Fill the PTU to specifications. Refer to WSM, Section 308-07 for correct procedure.
DB5Z-7034-C     Valve Assembly – Vent (Ti-VCT)
DG1Z-7034-F     Valve Assembly – Vent (GTDI)
XY-75W140-QL  Motorcraft® SAE 75W-140 Synthetic Rear Axle Lubricant
PM-4-A             Motorcraft® Metal Brake Parts Cleaner
150056A Attach Or Replace PTU Vent Hose, Includes Time To Check And Fill PTU And Clean Fluid Residue (Do Not Use With Any Other Labor Operations) 0.4 Hr.
150056B 2013-2014 Explorer And Taurus AWD With PTU Cooling: Attach Or Replace PTU Vent Hose, Includes Time To Check And Fill PTU And Clean Fluid Residue (Do Not Use With Any Other Labor Operations) 1.2 Hr.
WARRANTY STATUS
DEALER CODING
7034                      39
TSB 14-0186 (supersedes TSB 13-5-14)
TING/POP/CLICK NOISE – FRONT HALFSHAFT
Ting, Pop or Click Noise From the Front Wheel Area When Accelerating From a Stop, on Turns or When Shifting Between Drive/Reverse and/or Reverse/Drive
Publication Date: October 6, 2014
FORD:  2011-2014 Flex; 2011-2015 Explorer, Taurus
LINCOLN:  2011-2014 MKS, MKT
This article supersedes TSB 13-5-14 to update the vehicle model years, Issue Statement and Part List.
ISSUE:
Some 2011-2015 Explorer, Taurus, 2011-2014 Flex, MKT and MKS vehicles may exhibit a noise that could be described as ting, pop or click noise from the front wheel area when accelerating from a stop, on turns or when shifting between drive/reverse and/or reverse/drive.
ACTION:
Follow the Service Procedure Steps to correct the condition.
SERVICE PROCEDURE
1.Separate the halfshaft from the wheel hub. Refer to Workshop Manual (WSM), Section 205-04. a.Do not remove the halfshafts from the transmission or power transfer unit (PTU).
2.Install one (1) thrust washer, metal surface first, over the halfshaft splines until the metal ring is flat against the wheel bearing mating surface. The nylon surface should face outward toward the hub/splines. (Figures 1 and 2)
Figure 1 – 14-0186
Figure 2 - 14-0186
3.Install the halfshaft to wheel hub. Refer to WSM, Section 205-04.
BB5Z-7G273-B   Washer – Thrust
W712435-S439  Nut – Wheel Hub
W714890-S440  Nut – Ball Joint
W713968-S440  Nut – Sway Bar Link
W714890-S440  Nut – Tie Rod End
W500220-S439  Bolt – Dynamic Suspension
140186A 2011-2014 MKT, MKS: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.8 Hr.
140186B 2011-2014 MKT, MKS: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.2 Hrs.
140186C 2011-2014 Flex 2011-2015 Taurus: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.7 Hr.
140186D 2011-2014 Flex 2011-2015 Taurus: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.1 Hrs.
140186E 2011-2015 Explorer: Install A Thrust Washer Onto One (1) Front Halfshaft Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.7 Hr.
140186F 2011-2015 Explorer: Install A Thrust Washer Onto Both (2) Front Halfshafts Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.0 Hr.
WARRANTY STATUS
DEALER CODING
3B436                     42
TSB 15-0086 (supersedes TSB 14-0196)
3.5L GTDI – EXCESSIVE OIL CONSUMPTION AND/OR SMOKE FROM THE EXHAUST AT IDLE DURING NORMAL ENGINE OPERATING TEMPERATURE – ALUMINUM VALVE COVER
Publication Date: May 27, 2015
FORD:  2010-2014 Flex, Taurus; 2013-2014 Explorer
LINCOLN:  2010-2014 MKS, MKT
The article supersedes TSB 14-0196 to update the Part List.
ISSUE:
Some 2010-2014 Flex, MKS, MKT, Taurus and 2013-2014 Explorer vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine with an aluminum valve cover may exhibit excessive oil consumption and/or an excessive engine oil smoking condition from the tailpipe at idle during normal engine operating temperatures.
ACTION:
SERVICE PROCEDURE
1.Remove the positive crankcase ventilation (PCV) valve. Refer to Workshop Manual (WSM), Section 303-08.
2.Inspect for oil in the crankcase vent oil separator through the PCV valve opening. Is there presence of liquid oil, more than a slight vapor?
  a.No – this article does not apply refer to WSM, Section 303-00 for excessive engine oil consumption.
  b.Yes – proceed to Step 3.
3.Replace the right hand valve cover, refer to WSM, Section 303-01.
4.Replace the crankcase vent oil separator, refer to WSM, Section 303-08.
5.Drive the vehicle at normal operating temperature for 20 minutes at constant highway speed to remove oil residue from the catalytic converter.
AA5Z-6582-E    Valve Cover
AA5Z-6A666-D   PCV Valve
AA5Z-6A785-F   Crankcase Vent Oil Separator
TA-357         Motorcraft® High Performance Engine RTV Silicone
XO-5W30-QSP    Motorcraft® SAE 5W-30 Premium Synthetic Blend Motor Oil
ZC-31-B        Motorcraft® Metal Surface Prep Wipes
ZC-30-A        Motorcraft® Silicone Gasket Remover
150086A 2013-2014 Explorer 2010-2014 Taurus, MKS, Flex And MKT 3.5L GTDI: Inspect For Oil In The Crankcase Vent Oil Separator. None Found Includes Time To Replace PCV Valve (Do Not Use With Any Other Labor Operations) 0.3 Hr.
150086B 2013-2014 Explorer 3.5L GTDI: Inspect For Oil In The Crankcase Vent Oil Separator. Replace Right Hand Valve Cover, Crankcase Vent Oil Separator, PCV Valve Includes Time For Road Test (Do Not Use With Any Other Labor Operations) 2.1 Hrs.
150086B 2010-2014 Flex, MKT, Taurus And MKS 3.5L GTDI: Inspect For Oil In The Crankcase Vent Oil Separator. Replace Right Hand Valve Cover, Crankcase Vent Oil Separator, PCV Valve Includes Time For Road Test (Do Not Use With Any Other Labor Operations) 2.2 Hrs.
WARRANTY STATUS
DEALER CODING
6A785                    42
TSB 14-0198 (supersedes TSB 13-4-19)
EXHAUST – SULFUR ODOR AFTER HARD ACCELERATION
Publication Date: October 27, 2014
FORD:  2009-2014 Flex
This article supersedes TSB 13-4-19 to update the vehicle model years.
ISSUE:
Some 2009-2014 Flex vehicles may exhibit an exhaust odor in the vehicle with the auxiliary climate control system on. This may be more pronounced after hard acceleration or driving in hilly conditions. Customers may indicate the odor smells like sulfur.
ACTION:
SERVICE PROCEDURE
1.Remove the rear bumper cover. Refer to Workshop Manual (WSM), Section 501-19.
2.Inspect the attachment points on the bumper cover. Does foam surround the attachment points? (Figure 1)
Figure 1 - 14-0198
  a.Yes – proceed to Step 3.
  b.No – install foam around the missing attachment point locations. Proceed to Step 3.
3.Replace the left side upper / rear air extractor. (Figure 2)
Figure 2 - 14-0198
4.Is the vehicle a 2012 – 2014 Flex?
  a.Yes – proceed to Step 5.
  b.No – replace both lower / forward air extractors. Proceed to Step 5. (Figure 3)
Figure 3 - 14-0198
5.Remove the liftgate release switch moulding. Refer to WSM, Section 501-14.
6.Install foam from the Rotunda Squeak and Rattle Repair Kit (164-R4901) around the liftgate release switch moulding opening on the liftgate. (Figure 4)
Figure 4 - 14-0198
7.Install the liftgate release switch moulding. Refer to WSM, Section 501-14.
8.Install foam from the Rotunda Squeak and Rattle Repair Kit (164-R4901) around the four (4) tail lamp assembly attachment holes. Cut pieces large enough to fully cover the attachment point. (Figure 5)
Figure 5 - 14-0198
9.Open the liftgate and install a new drain valve in each of the three (3) drain holes. (Figure 6)
Figure 6 - 14-0198
10.Raise the vehicle on hoist. Refer to WSM, Section 100-02.
11.Lower and support the rear section of the exhaust system.
12.Clean the areas on the underside of the vehicle where seam sealer will be applied. (Figures 7-9)
Figure 7 - 14-0198
Figure 8 - 14-0198
Figure 9 - 14-0198
13.Cover the exhaust system and auxiliary climate control drain.
14.Apply a generous amount of Motorcraft® Seam Sealer to the rear horizontal sheet metal lap joints on the left and right sides of the vehicle, and the rear sheet metal overlap flange across the rear of the vehicle. (Figures 7-9)
15.Spray a generous amount of 3M™ Rubberized Undercoating around auxiliary the air conditioning lines and seam sealer areas. (Figure 10)
Figure 10 - 14-0198
16.Install the rear exhaust system.
17.Install the rear bumper cover. Refer to WSM, Section 501-19.
Part Number  Part Name
08883          3M™ Rubberized Undercoating
164-R4901    Foam – Rotunda Squeak And Rattle Repair Kit
AL2Z-61280B62-A  Grille – Air Inlet (Forward/Lower) (2 Req)
DA8Z-78280B62-A  Grille – Air Inlet (Rear/Upper)
4M8Z-54280B62-A  Valve Assembly Auto Drain (3 Req)
140198A 2009-2014 Flex: Seal Body Includes Time To Replace Air Extractors Install Liftgate Drain Valves (Do Not Use With Any Other Labor Operations) 2.0 Hrs.
WARRANTY STATUS
DEALER CODING
78280B62              68
TSB 14-0223
2.0L GTDI – LACK OF POWER – DTC P2111, P2101 AND/OR P2112 – AMBIENT TEMPERATURES BELOW 0 DEGREES CELSIUS (32 DEGREES FAHRENHEIT) BUILT ON OR BEFORE 10/5/2014
Publication Date: December 12, 2014
FORD:  2012-2015 Explorer; 2013-2015 Taurus
ISSUE:
Some 2012-2015 Explorer and 2013-2015 Taurus vehicles equipped with 2.0L Gasoline Turbocharged Direct Injection (GTDI) engines and built on or before 10/5/2014 may exhibit a lack of power and a malfunction indicator lamp (MIL) illuminated with diagnostic trouble code (DTC) P2111, P2101 and/or P2112 stored in powertrain control module (PCM) memory, in ambient temperatures below 0 °C (32 °F).
ACTION:
SERVICE PROCEDURE
1.Does the condition occur in ambient temperatures below 0 °C (32 °F)?
  a.Yes – proceed to Step 2.
  b.No – this article does not apply. Refer to Powertrain Control/Emission Diagnosis (PC/ED) manual for normal diagnosis.
2.Using Integrated Diagnostic System (IDS) service tool or equivalent, check for DTCs.
3.Are DTC P2111, P2101 or P2112 stored in PCM memory and, in some instances, does the vehicle exhibit a lack of power?
  a.Yes – proceed to Step 4.
  b.No – this article does not apply. Refer to PC/ED manual for normal diagnosis.
4.Remove and replace the charge air cooler (CAC) tube and screen assembly from the CAC to the throttle body with the revised part. Refer to Workshop Manual (WSM), Section 303-12.
CB5Z-6C640-B   Charge Air Cooler Tube
140223A 2013-2015 Taurus And 2012-2015 Explorer 2.0L GTDI: Retrieve DTCs And Replace CAC Tube Between The CAC And Throttle Body (Do Not Use With Any Other labor Operations) 0.5 Hr.
WARRANTY STATUS
DEALER CODING
9424                    42
TSB 15-0047 (supersedes TSB 14-0209)
SHIFT TO PARK OR TRANSMISSION NOT IN PARK MESSAGE – DISCHARGED BATTERY DUE TO SHIFT TO PARK LIGHT ON / UNABLE TO REMOVE IKT
Publication Date: March 31, 2015
FORD: 2011-2014 Edge; 2011-2015 Explorer; 2013-2015 Flex, Taurus
LINCOLN: 2011-2015 MKX; 2013-2015 MKS, MKT
This article supersedes TSB 14-0209 to add a production fix date.
ISSUE:
Some 2011-2014 Edge, 2011-2015 MKX, Explorer and 2013-2015 Flex, MKS, Taurus vehicles built on or before 12/01/2014, and 2013-2015 MKT vehicles built on or before 03/16/2015 equipped with a floor shift selector lever may exhibit a Shift To Park message, Transmission Not In Park message displayed while the shifter is in park position, or unable to remove the integrated keyhead transmitter (IKT), or a discharged battery due to the Shift to Park light remaining illuminated.
ACTION:
SERVICE PROCEDURE
1.Replace the selector lever assembly. Refer to Workshop Manual (WSM), Section 307-05.
2.Adjust the selector lever cable. Follow the selector lever cable adjustment procedure in the WSM, Section 307-05.
7210                    Selector Lever Assembly (See Parts Catalog For Correct Trim Level Part)
150047A 2013-2015 Flex, Taurus 2.0L GTDI: Replace The Selector Lever Assembly (Do Not Use With Any Other Labor Operations) 0.6 Hr.
150047A 2013-2015 MKS: Replace The Selector Lever Assembly (Do Not Use With Any Other Labor Operations) 0.7 Hr.
150047A 2011-2015 Explorer, 2013-2015 MKT, Taurus, 2011-2014 Edge: Replace The Selector Lever Assembly (Do Not Use With Any Other Labor Operations) 0.8 Hr.
150047A 2011-2015 MKX: Replace The Selector Lever Assembly (Do Not Use With Any Other Labor Operations) 0.9 Hr.
WARRANTY STATUS
DEALER CODING
7210                       42
TSB 14-0231
MYFORD TOUCH – VARIOUS FUNCTIONALITY CONCERNS
Publication Date: December 19, 2014
FORD:  2011-2014 Explorer
ISSUE:
Some 2011-2014 Explorer vehicles located in Russia and equipped with MyFord Touch® may exhibit concerns with navigation, voice recognition, call sound quality, phone pairing, clock, media, WiFi pass code entry, rear view camera guidelines, no Russian language package and/or poor system performance.
ACTION:
SERVICE PROCEDURE
Run OASIS using the vehicle identification number (VIN) and verify there are no open Service Actions. All Service Actions must be completed before attempting to perform this procedure.
1.Determine the vehicle's current accessory protocol interface module (APIM) software level (CCPU S/W).
  a.On the front display interface module (FDIM), select:
       i.Menu
       ii.Help
       iii.System Information
  b.Note the last five numeric digits (e.g. 4.30.14073.PRODUCT) of the CCPU S/W version displayed.
2.Are the last five numeric digits of the CCPU S/W 14073 or higher?
  a.Yes – this article does not apply. Refer to Workshop Manual (WSM), Section 415-00 for normal diagnosis.
  b.No – proceed to SYNC® module APIM standard programming procedure. Refer to WSM, Section 415-00.
140231A 2011-2014 Explorer: Perform The SYNC APIM Standard Programming (Do Not Use With Any Other Labor Operations) 1.1 Hrs.
WARRANTY STATUS
DEALER CODING
14D212                   04
