Winter blend gas and E/85
Started by SHOnUup, October 12, 2014, 10:36:14 AM
Quote from: wasinger3000 on October 16, 2014, 12:14:31 PM
Now it's almost time to start mixing e98 in the tank while spraying meth. Should be interesting.
Do you think you will need a boost limiter?  LOL!
MDesign Performance
So a 2011 should be fine with a slight mix (2 gallons) of e85? Also what do you busy consider top tier e85? My car sees either Exxon Mobile 93 Octane or Shell 93 Octane religiously and none of these stations carry e85.
sales@mdesignperformance.com
www.mdesignperformance.com
wasinger3000
Quote from: SHOdded on October 16, 2014, 02:54:02 PM
Haha nah I have a built in one. They call it a claustrophobic connecting rod. Lol.
13' GTCS, will be missed.
Quote from: Spartn27 on October 16, 2014, 03:07:08 PM
I use Shell for 93 and Speedway for E.
Shell is top tier, unsure about Exxon.
Exxon is def top tier.  http://www.toptiergas.com/retailers.html  But all retailer facilities will not be equal.
Josephm
I try to only use shell as well
12' Flex EB
Unleashed X4
3rd Cat delete
Airbornemaikai
A lot of stations actually get their gas from the top tier stations anyway. You can usually find out by calling or checking their website
2014 Explorer Sport
LMS 91 Tune with 3 Bar Map
160º Evenflo T-stat, 0.30 Motorcraft plugs
LMS DP W/HI-Flow Cats, LMS Corsa Cat-Back
Airaid 401-260
Quote from: wasinger3000 on October 16, 2014, 03:22:28 PM
Just caught that...lol...very clever
Rich
wasinger3000
Quote from: SHOnUup on October 16, 2014, 11:50:40 PM
Rich
Hah, Sometimes I think i over do it.
Josephm
12' Flex EB
Unleashed X4
3rd Cat delete
ecoboostsho
Quote from: SHOnUup on October 15, 2014, 02:50:22 PM
Quote from: SHOdded on October 15, 2014, 02:44:30 PM
Great to hear!  That would make it, what, 18% or so?  Hope this will bear out over an extended run :)  Open some more doors for the Gen 4.1 folks!
Looking into exact blend as on the e/85 pump it says no lower than 70% ethonal. Did confirm that a branded BP supplier 93 has 9 or 10% guaranteed all year. Was trying to make sure it stayed under 20%.
Car pulled real hard and I can't describe how much smoother it felt. Max KR at WOT from a few different speeds was .8 with a lift knock of 2. Much better than the last week where I was getting up to 3.5 at WOT and an outrageous 5.2 lift knock.
Be careful out there with this winter gas everyone. This is the time to monitor closely.
Rich
Do you monitor the learned octane ratio by chance? Has it changed?
I dont. Didn't think of it at the time. Shucks
Rich
Quote from: FoMoCoSHO on October 15, 2014, 04:02:10 PM
Bp doesn't make E-85 so ask him what the name is on the side of the truck that delivers it. Then we can dig up the msds for it
Stopped at same station where the guy was very informative last time and he wasn't in this time. Stake out time...lol.
In the 4 runs at the track yesterday I recorded no knock whatsoever! Guessing this is the fuel mixing better and car learning it.
On the ride home the wife was driving and scored a .8 lift knock. Wondering if this is something to do with letting off with all that torque built up because at the track letting off at 110 didn't get any lift knock?
Rich
Larrylu
#43
I've been sticking with the same Gulf brand and station that showed me such an improvement in my KR readings a couple of months ago, and to my disappointment, this last tank is starting to show some low octane results. It started slowly but as I get deeper into this tankful, I'm up from a steady 2 to a 5.5. Maybe this sudden change can be attributed to winter gas and if so, I guess I'll have to run a 91 octane tune for the winter or experiment with mixing a couple gallons of E85 with my normal fill up. FWIW, I'm still not aware of the driving activity that produces my high reading. When I watch, full throttle or lift off do not produce a high reading. But in normal driving if I take my eyes off the gauge for a few minutes, a spike is captured. I'm going to see if I can get my KR gauge to give me an audible feedback on high readings.
Quote from: Larrylu on October 21, 2014, 10:39:08 AM
I've been sticking with the same Gulf brand and station that showed me such an improvement in my KR readings a couple of months ago, and to my disappointment, this last tank is starting to show some low octane results. It started slowly but as I get deeper into this tankful, I'm up from a steady 2 to a 5.5. Maybe this sudden change can be attributed to winter gas and if so, I guess I'll have to run a 91 octane tune for the winter. FWIW, I'm still not aware of the driving activity that produces my high reading. When I watch, full throttle or lift off do not produce a high reading. But in normal driving if I take my eyes off the gauge for a few minutes, a spike is captured. I'm going to see if I can get my KR gauge to give me an audible feedback on high readings.
I was noticing same thing Larry. My WOT pulls would show more than normal but not as bad medium throttle in normal conditions. My lift knock spiked as well.
Also seeing that the car needs to be fully warmed up to not register knock on these cold mornings. Noticing a few extra minutes does a world of difference here.
Big thanks to the GURUS in the Torque PID'S thread for making this a posibility. Probably the best investment made for the car yet is the ability to monitor this stuff.
Rich
