Larry - It's worth looking at. Torque actually has a built in gauge that will tell you when it is open or closed loop. The KR I get is almost exactly as you describe and occurs right BEFORE it goes in to closed loop (i.e. still in open loop) It starts occurring at a temp of about 145 degrees but only in 6th with a very small amount of throttle- it goes in to closed loop around 158/160. E-85 blend helps with the spike but I've actually figured out if I shift manually and stay out of 6th gear and keep the RPM's between about 2 and 3K (higher is fine but the car is warming up so I don't want to rev it out) then it won't occur. Once the car is at 160 I just pop it in D and move along. Once the car is in closed loop it is fine. I still plan on logging and see if I can understand what is going on. I'm not sure if there is a temperature timing adder just in open loop that causes the timing to advance to a point where it just knocks too easy. I will be logging throttle %, Coolant Temp, Knock, Timing, RPM, open/closed loop, AFR, and possibly engine load. If I can recreate it I can at least see what kind of timing it is calling for and go from there...
