Oil Return Line/Tube TSB Part #
Started by MDesign Performance, October 02, 2014, 10:19:32 AM
MDesign Performance
There was a TSB on the leaking oil return line, I believe first they tried replacing the gasket and then there was a complete updated tube return line replacement. Anyone have the TSB and part numbers? I'm thinking of updating both my turbo return lines as a precaution and one of them is actually leaking a bit.
sales@mdesignperformance.com
www.mdesignperformance.com
This one?  TSB-14-0105
3.5L GTDI-EXCESSIVE OIL CONSUMPTION AND /OR SMOKE FROM THE EXHAUST AT IDLE DURING NORMAL ENGINE OPERATING TEMPERATURE-ALUMINUM VALVE COVER
Description: FORD/LINCOLN: SOME VEHICLES MAY EXPERIENCE A ROUGH IDLE, IN GASOLINE TURBOCHARGED DIRECT INJECTION (GTDI) ENGINE, MAY OCCUR AFTER HOT START. MODEL 2012-2014 FLEX, TAURUS, EXPLORER, MKT. *PE
Repair Information for NHTSA #10056139
or this one? TSB-14-0113
Description: FORD/LINCOLN: SOME VEHICLES, WITH ALUMINUM VALVE COVER, WILL EXPERIENCE AN EXCESSIVE CONDITION OF SMOKING ENGINE OIL AND/OR CONSUMPTION OF OIL, FROM TAIL PIPE, DURING NORMAL ENGINE TEMPERATURE OPERATION. MODEL 2010-2014 FLEX, TAURUS, EXP
or this service advisory:
TSB #AS-21759 / NHTSA ID #10039108
Date Announced:  MARCH 01 2011
Additional Info:  How to Fix
Summary: FORD: 2010-2011 TAURUS. THERE MAY BE AN OIL LEAK FROM THE TURBOCHARGER OIL FEED LINES OR A SEAL. *RM
http://www.fordtaurus.net/forums/viewtopic.php?f=46&t=14855 (relevant post quoted below)
Post subject: Re: Burnt Oil Smell?
PostPosted: Wed Jan 04, 2012 10:28 pm
I just found some interesting info on another forum:
Post 1:
they did a thorough inspection of the car today when the oil change was performed. After removing the splash guard, they checked the PTU (as that was high on the list for leaks). Apparently it was dry as a bone. They did however find some SSM's #21930 (part: 9T515), 21759 that were specific to leaking seals on the Turbo oil lines O rings. And that is where they found the issues. It would appear that the Turbo oil line O ring seals had weakened, and of course when under high temps, heavy load, the oil was dripping very slowly down onto the exhaust. Thus the lingering burning oil smell, nearly almost always after freeway/spirited driving. Needless to say, replacement parts have been ordered and the car should be getting fixed very shortly into the new year. Look forward to not smelling burnt oil after driving...as I almost always drive a little spirited.
Post 2:
A very good member of this forum was able to get me the listings for the codes that I stated above. Spells out the issue very nicely. I wanted to post this information for other EB owners that may come to experience the burnt oil smell on an intermittent basis after driving in a spirited manner.
Code:
21930 3.5L GTDI ENGINES BUILT BEFORE 1/11/2010 - TURBO OIL DRAIN TUBE GASKET NO LONGER AVAILABLE - REVISED TURBO OIL TUBE AVAILABLE
FOR 2010 TAURUS, FLEX, MKS, AND MKT VEHICLES EQUIPPED WITH THE 3.5L ECOBOOST ENGINE, WITH ENGINE BUILD DATE BEFORE 1/11/2010, THE GASKET BETWEEN THE TURBO CHARGER AND TURBO CHARGER OIL RETURN TUBE FLANGE IS NO LONGER AVAILABLE FOR SERVICE REQUIRING THE PURCHASE OF A TUBE ASSEMBLY (BASE 9T515.) TO DETERMINE THE VEHICLES ENGINE BUILD DATE, REFER TO WORKSHOP MANUAL SECTION 303-01B. NOTE: DO NOT ATTEMPT TO INSTALL THE UPDATED AVAILABLE GASKET ON AN OLDER TUBE.
EFFECTIVE DATE: 06/20/2011
Code:
21759 2010-2011 TAURUS SHO, MKS, FLEX, AND MKT 3.5L ECOBOOST TURBO CHARGER OIL FEED AND RETURN LINE OIL LEAKS.
SOME 2010-2011 MODEL YEAR VEHICLES EQUIPPED WITH A 3.5L GTDI (ECOBOOST) ENGINE MAY EXHIBIT AN OIL LEAK FROM THE TURBOCHARGER OIL FEED LINE AT THE BANJO BOLT CONNECTION OR THE SEAL ON THE OIL RETURN LINES. THESE LEAKS MAY APPEAR TO BE COMING FROM THE TURBOCHARGER ITSELF. CLOSELY INSPECT THE BANJO BOLT SEALS ON THE FEED LINE AND SEALS ON THE RETURN LINE FOR LEAKS AND REPAIR AS NECESSARY. CLEAN ALL ACCUMULATED RESIDUAL OIL FROM THE TURBOCHARGER V-CLAMP. DO NOT LOOSEN OR REMOVE THE V-CLAMP FOR CLEANING. TURBOCHARGER REPLACEMENT WILL NOT RESOLVE THIS SYMPTOM.
EFFECTIVE DATE: 03/01/2011
Lets see what my dealer says
MDesign Performance
Yea I searched for some part numbers and just want to make sure I am not re-purchasing what is already on the car and that they are the updated parts. Anyone know if this is it?
Left Return Line: AA5Z-9T515-E
Right Return Line: AA5Z-9T515-G
Anyone confirm if these are the ones used for the TSB's? Thanks in advance.
Tasca Ford has the left line for 18.00 and the right lower for 16.00 plus shipping,maybe they could give us an update.
black99lightning
2013 Esport 13.44 @ 103.6
1999 Lightning 12.44 @ 108.4
2012 GT500 10.96 @ 130.6
2006 GTO 12.83 @ 107.8
2013 CTSV coupe 11.79 @ 119.7
MDesign Performance
Yea it's cheap enough and seems simple enough to swap on your own instead of going to the dealer.
CroR1
Does anyone know if this is the issue for the smoking exhaust after downpipes install, or is it the turbo seals?
gad
Quote from: cror1 on October 22, 2014, 01:09:10 PM
same problem, after hard acceleration , blue smoke in  my back window,  only deceleration...
10 SHO, torrie tune, whatermeth , DP catless, H&R spring, t-stat 170, air raid intake, best time 12.19@110 mph.(1.74 0-60ft)
herbiethemisfit
So I replaced both oil return lines but I still have a leak on mine, so I'm suspecting it's the oil feed line (banjo bolt) that is the source.  Anyone know what the actual fix is for that?  The TSB just says to "repair as necessary".  Is it just replacing the crush washers and re-torquing??
I tried searching for the full text of that TSB, but didn't find anything.
Spenser281
Any updates on this?  It looks like I may be experiencing the same issue.  It sure as hell looks like a turbo seal leaking on the rear, but I suppose it could be the lines.  I see the part #'s for the return lines.  Are there any part #'s for the feed lines with hardware?
Sent from my SAMSUNG-SM-G900A using Tapatalk
2010 SHO
Work in progress....
Can't confirm, but based on part numbers and what they are called:
For a 2010 SHO:
6   GB5Z-9G440-A   UPPER PIPE, RIGHT
$58.12   $40.10
7   AA5Z-9T516-AF   UPPER PIPE, LEFT
$63.06   $36.26
8   AA5Z-00812-AB   UPPER PIPE BOLT, RIGHT
$8.00   $4.60
8   AA5Z-00812-AB   UPPER PIPE BOLT, LEFT
$8.00   $4.60
9   AA5Z-6A863-B   UPPER PIPE CONNECTOR, RIGHT
$23.22   $16.02
9   AA5Z-6A863-B   UPPER PIPE CONNECTOR, LEFT
https://secure.revolutionparts.com/levittown-ford/auto-parts/2010/ford/taurus/sho-trim/3-5l-v6-gas-engine/engine-cat/turbocharger-and-components-scat
There were like 4 revisions to those oil supply & return lines, since the 2010 model year.
All due to oil leaking.
Quadruple check any part #'s, & be sure you have the latest revision.
pmezo33
I've got two turbos slightly leaking oil.  Oil level never drops, but it's definitely leaking.  Replaced both feeder and return lines and it's still leaking.  Not really sure to go from here other than replacing the turbos completely at some point.  It doesn't affect anything - no codes, performance is fine, etc.  But it's definitely leaking a little bit when inspecting from under the car.
Is your exhaust stock?  Wondering if its too late for the seals ...
