Started by IA 5HO, September 24, 2014, 08:33:11 PM
Quote from: IA 5HO on September 24, 2014, 08:33:11 PMAlso, after dipping my fender emblems, I noticed the driver side and curb side ones are different for me, if you look at one, the diamonds are smooth, while the other side has a texture to them.
Quote from: panther427 on September 24, 2014, 09:00:52 PMLooks amazing. Love that blue. Nice work
Quote from: PokerMunkee on September 24, 2014, 10:22:12 PMHow many cans did you need?
Quote from: vernonator on September 25, 2014, 08:45:02 AMDo you work downtown Des Moines? I think I may see you occasionally coming in. I drive in from Elkhart - Blk 2012 SHO...Nice look!!!
Quote from: Wild13SHO on September 25, 2014, 09:42:44 PMLooks good, nice work! Did you pull the pieces off, buy an extra set?
Quote from: IA 5HO on September 25, 2014, 09:01:33 PMThanks for all the positive feed back everyone!Quote from: PokerMunkee on September 24, 2014, 10:22:12 PMHow many cans did you need?I ended up using just over 2 cans, giving about 3-4 coats of matte black only. Although I did end up re-doing the front and rear ends once each due to a bad turn out, so if everything goes well in one shot you might get by with just 2.Quote from: vernonator on September 25, 2014, 08:45:02 AMDo you work downtown Des Moines? I think I may see you occasionally coming in. I drive in from Elkhart - Blk 2012 SHO...Nice look!!!Yep, I do work near downtown, I come in from Ankeny. Just moved to the area a few months ago. I'll keep a look out for you then! Although I have a hard time spotting the 10-12 SHO's
Quote from: wasinger3000 on September 26, 2014, 09:41:15 AMHow hard is it to get the window trim off? I like to do this. But don't want to tear stuff up.
Quote from: BiGMaC on September 26, 2014, 12:17:59 PMQuote from: wasinger3000 on September 26, 2014, 09:41:15 AMHow hard is it to get the window trim off? I like to do this. But don't want to tear stuff up. Most of the posts about removing it explain about bending it and replacing it...
