January 28, 2020, 07:10:12 PM
Author Topic: "How-To" 5000K Switchbacks and sidemarkers installed! - ShoBoat  (Read 626933 times)
Offline EcoPowerParts
  • How can I help you today?
  • : Phoenix
  • -Given: 147
  • -Received: 1191
    • EcoPowerParts
Originally posted by ShoBoat
This mod has taken me quite some time to complete, I sourced the LED bulbs locally and the color was always off. They all had quite a bit of blue in the bulbs. Some almost to the point of being purple?? So I mucked around with this for a few weeks. I even changed the HID's to 6000K just to get it to match. No dice as the LED lower markers are about a 5000K color. Just my 2 cents if you want to match your OEM 4300K HID and the OEM lower LED markers get the ones I have listed. I literately went through 3 sets of switch back bulbs before these.
The running lights are really bright. almost like adding a set of fog lights. Also on approach when you unlock the car they light up the areas in front of the car really well.
The Switchbacks are VLEDS 5000K 3157 Type 2 dual color bulbs
The Corners are 5000K 194 Bulbs
You will also need a pair of load resistors to eliminate hyper-flash. I went with 8 ohm 50W but 6 ohm 50W is more readily available and will work too.
The install is fairly simple (sort of lol)
The switchbacks are easier to install and you can access from inside the engine compartment. Driver side is piece of cake. Remove the socket and plug in the bulb. You need to use wire taps to link the load resistor to the 2 outside wires on the harness. I would double check with a volt meeter which is ground and the turn signal. Mount the load resistor to metal. I mounted mine to the inner fender wells with Loctite 3873 is a fast curing, high-conductivity, adhesive. And that seemed to work well. On the passenger side it was a little harder to get the wire taps on. I removed the tube going to the throttle body to give me more space to work.
The side markers are a PITA!. You will have to remove the wheel and the plastic outer fender well. Once you have those off now begins the cursing. If your hands are small enough you can reach up and grab the socket and twist it out. My hands are not that small (what was ford thinking?) Instead I used a long pair of needle nose pliers to just twist the socket enough to break to free. Then I was able to get my fingers on it and remove it. Installation is also a PITA, you have to insert the bulb and socket had just get it to grab with your hand. Once you do then and only then use the pliers carefully. You could break the housing if not careful. Done, just put if back together and enjoy!!
I'll add the links to the products below.
http://www.vleds.com/5k-type-2-dual-color-changing-white-amber-switchback-42-high-power-led-turn-signal-bulbs-3157-4157-1-pair.html
http://www.vleds.com/bulb/194-168-158-led/5k-white-led/5k-white-10-led-light-bulbs-194-158-168-2825-1-pair.html
http://www.vleds.com/resistors/led-load-equalizer-resistors-turn-signal-blinker-fix-1-pair.html
http://www.henkel.com/fullproductlist-electronics.htm?countryCode=us&BU=industrial&parentredDotUID=productfinder&redDotUID=90000000057&categoryspecificredDotUID=00000002KJ
« Last Edit: July 14, 2013, 09:59:13 AM by 4DRHTRD »
Offline ShoBoat
  • : Canada
  • -Given: 93
  • -Received: 257
Re: 5000K Switchbacks and sidemarkers installed! - ShoBoat
« Reply #1 on: June 17, 2013, 01:14:44 PM »
A Pic of the resistor location for reference.
2012 Pearl White CTS-V Stock
Offline abnjeffy
  • Jr. Member
  • -Given: 0
  • -Received: 0
Re: "How-To" 5000K Switchbacks and sidemarkers installed! - ShoBoat
« Reply #2 on: November 22, 2013, 07:12:07 AM »
I just found this and am going to give it a shot.  What brand HID's are used in the original thread?  I want to get a pair to and make sure the color matches
---2013 Taurus Limited, non-SHO---
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • : Gilbert - SE Phoenix Metro Area
  • -Given: 1155
  • -Received: 705
« Reply #3 on: November 22, 2013, 07:54:14 AM »
Welcome... glad you joined!  :cheers:
I think ShoBoat ended up using OEM HIDs...
"Just my 2 cents if you want to match your OEM 4300K HID and the OEM lower LED markers get the ones I have listed. I literately went through 3 sets of switch back bulbs before these....
You will also need a pair of load resistors to eliminate hyper-flash. I went with 8 ohm 50W but 6 ohm 50W is more readily available and will work too."
The links posted work.
Maybe Shoboat will weigh in. I PM'd him.  :secret:
« Last Edit: November 22, 2013, 08:03:09 AM by BiGMaC »
2013 Taurus SHO nonPP - All Ford factory options, 3BAR MAP, LMS v8 tune (mods for 3BAR, DPs, and T-stat), Paint & plastic correction, CQuart finest all exterior surfaces, limo black window tint,VLED Triton switchbacks, Daytime BrightLites switchback DRLs, full interior and exterior LED conversion, Lamin-X charcoal blackout tail lights and reflectors, PPE catted and coated downpipes, EBPP coated hotpipes with BoVs VTA, MDesign CAI
2013 F250 CC Lariat 6.7EB Diesel -stock
Offline Kolk1
  • Sr. Member
  • : Alton IL
  • -Given: 6
  • -Received: 37
« Reply #4 on: November 22, 2013, 06:57:27 PM »
I did a write up with wiring color, for switch backs that I did on my 11'. But It was on EBOF.
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • -Given: 1155
  • -Received: 705
« Reply #5 on: November 22, 2013, 07:26:30 PM »
Cool... can you post a direct link please.  TIA
Offline Kolk1
  • Sr. Member
  • : Alton IL
  • -Given: 6
  • -Received: 37
« Reply #6 on: November 22, 2013, 08:14:44 PM »
Nope, ever since the board update over there, all of my DIYs are gone. Really pisses me off. I had a TON. Remote Start system, with viper or OEM key fob, switch back LEDs, Toggle switch for Fans, Stereo install, front speakers, sub amp install, wiring diagrams, you name it.
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • -Given: 1155
  • -Received: 705
« Reply #7 on: November 22, 2013, 10:19:08 PM »
Not much attention to detail there I guess. It sux when you put in the time to provide help to others and then it just gets trashed.
 :blowup:
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12390
  • -Received: 4071
« Reply #8 on: November 23, 2013, 01:02:48 AM »
Yea, and Kolk had some pretty detailed writeups, very clear & informative with pics.  Let me see if I can root out anything over there.
EDIT:  I found some on LEDs etc.  But I am not allowed to post the link to EBOF anymore, so maybe I can have 4DR import the info?  I will PM him.
« Last Edit: November 23, 2013, 01:05:34 AM by SHOdded »
Offline abnjeffy
  • Jr. Member
  • -Given: 0
  • -Received: 0
« Reply #9 on: November 24, 2013, 12:51:02 PM »
BiGMaC,
The link for 194's is not working but those are easy enough to find.  I am having trouble differentiating between crappy and good HID kits online.  I want to go with a 5k kit but am not sure on a brand
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • -Given: 1155
  • -Received: 705
« Reply #10 on: November 24, 2013, 01:35:15 PM »
I agree with 5K... Me2.   I'm trying to find out if anyone has experience with the Triton V3 LEDs... http://www.vleds.com/bulb.html
Offline abnjeffy
  • Jr. Member
  • -Given: 0
  • -Received: 0
« Reply #11 on: November 24, 2013, 02:25:29 PM »
Well I am about to pull the trigger on a set of the V3's so I don't have to do any additional wiring.  Problem is, I want to do it all at once and am having trouble settling on an HID kit
« Last Edit: November 24, 2013, 02:32:38 PM by abnjeffy »
Offline abnjeffy
  • Jr. Member
  • -Given: 0
  • -Received: 0
« Reply #12 on: January 26, 2014, 12:25:35 PM »
I finally got a set of the Triton V3's, LED side markers and HIDs.  I am having issues deciding where to begin on the HID install, can anyone give me advie one how to get started?  I just don't really know how the wiring works and where to put it all
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • -Given: 1155
  • -Received: 705
« Reply #13 on: January 26, 2014, 02:27:25 PM »
abnjeffy....
What year and model ride do you have... Maybe put it in your signature so questions can be answered better for you.
The triton instal with the new ford adapter is plug and play... see my post
http://www.ecoboostperformanceforum.com/index.php?topic=1730.msg22650#msg22650
You may have to remove the front clip (bumper) to change the headlight cowl... hard to say right now  more info on your ride please and a pic of your HID kit or part#.
Offline abnjeffy
  • Jr. Member
  • -Given: 0
  • -Received: 0
« Reply #14 on: January 29, 2014, 08:18:07 AM »
sorry about the lack of info, it's a 2013 non-SHO Taurus Limited.  I have this HID kit from VLEDs
http://www.vleds.com/hid-242/hid-conversion-kits/9006/9006-morimoto-elite-hid-system.html
As for the Triton's, I think I've got that figured out but I'm waiting on the Ford-specific connectors from them that I didn't know I needed.
I just don't really know where to put all the wiring for the HIDs and the ballasts and how to run everything.  It's a bit overwhelming to look at it all
* Featured Topics
* Recent Topics
Re: Post a Pic of your Ecoboost!
by StinkinLinkin13 | January 27, 2020, 11:05:34 PM
Gray day beads.. ...
Re: New Bro
by ridered74 | January 27, 2020, 08:37:32 PM
Little update. Wednesday she is going to the local performance shop an...
Re: Phenolic Spacers
by 802SHO | January 27, 2020, 05:00:14 PM
I sent an email too!  Figured might as well right?  Hopefull...
by bpd1151 | January 27, 2020, 01:15:34 PM
ATP's scrapped. GH turbos now planned. They should be getting my ...
New Filters & Rebates at RockAuto.com
by RockAuto | January 27, 2020, 01:04:33 PM
ACDelco Filter Rebates:Save even more on RockAuto's reliably low ...
by bpd1151 | January 27, 2020, 12:32:11 PM
01/27/20......Placed an email inquiry to x35 Designs, in regards to th...
Re: RockAuto Discount Code for Parts & More - Expires March 30, 2020
by skippytx | January 27, 2020, 11:12:09 AM
Thanks for the discount code all.  Saved me 15 bucks on my pads ...
Re: 2014 Lincoln MKS EcoBoost with all the goodies $14,900
by Nova | January 26, 2020, 08:54:58 PM
I actually plan to do exactly that, but at the drag strip here in Orla...
Re: In car temp sensor rattle
by IGottaShoYou | January 26, 2020, 03:52:05 PM
I can't say anything on your, but most of the interior temp senso...
Re: 2013 SHO Suspension Work
by ZSHO | January 25, 2020, 02:10:31 PM
Yes it is routine to replace the hub nut every time the old one is rem...
Re: Friction modifier in rear end
by SHOdded | January 25, 2020, 12:39:49 AM
No.  The clutch pack is sealed, and only the gears are serviced w...
Re: Auto tilting reverse mirrors working help?
by jdsfel | January 23, 2020, 04:36:38 PM
Hey @Gjkrisa,  did you ever get this working?  I am planning...
DIY dual Amazon catch can
by ChrisxHowe | January 23, 2020, 02:33:28 PM
Made my own catch can set up with 2 catch cans from Amazon and some 1/...
Re: Quality time with my Son washing the Lincoln
by PDSHO | January 23, 2020, 02:10:45 PM
One year we took a vacation to Yellowstone when I was a kid, my only r...
My car hates me
by Spyder3000gtvr4 | January 23, 2020, 12:20:09 PM
So 5k later cars finally on the road with a bit of new parts and of co...
Back to top
