Strange rear tire wear.
Started by glock-coma, September 28, 2014, 01:55:09 PM
Noticed some strange tire wear on my rear passenger tire today.
Compared to the rear drivers side.
That's strange.  Almost like to passenger side camber is off so the top tilts out.  Is the inside the same?  Another thought is chirping on rear tire more.
4wheel alignment checked?
Inside is completely normal.
Have not had an alignment yet. Just noticed this today.
11BLKFX4EB
Ive been hearing that we are supposed to rotate, balance and check alignment every 6000 miles on these cars
2014 SHO w/ PP Platinum White
Unleashed tuned, H&R Springs, 35% tint, Corsa catback coming...
2015 Explorer Sport Magnetic Metallic-stock...for now.
IF you dont hear any abnormal noise your due for a four wheel alighnment as BigMac stated earlier,rough road conditions such as potholes will throw off the alighnment causing outer tire wear,usually a bad control arm and bushing will cause inner tire wear,but when the alighnment is performed to dealer specs make sure to check the work order to see what excactly needed adjustment and by how much,especially that rear tire.
